Sd1540 B 3 point problems
/ Sd1540 B 3 point problems #1
Neil1982
2008 Massey Ferguson GC2310
My 3 point will only lift when cold and at that it will lift and then drop with weight on it. I have replaced the piston O rings and the problem still persisted.
Any ideas what else it could be?
I have a loader on it and it works perfectly.
/ Sd1540 B 3 point problems #2
Did you check out your other thread posting. I provided the manuals. :)
Bet there are other o-rings in the system to check. And it may be a diverter valve being stuck too.
So I have replaced the O rings on the piston, honed the cylinder, replaced all O rings in the control valve, flushed all the hydro fluid and put a new screen in and I am still having the issue where it won’t lift. Any one have a suggestion as to what else it could be? Again front loader works perfect.
/ Sd1540 B 3 point problems #4
Old post but I’ve been having the same issue. Did you ever figure out what it was?
/ Sd1540 B 3 point problems #5
I just acquired a 1980 shibaura sd1500b, 3 point lift picks up good at first start,, but will ease back down (grader box 4ft), hotter gets the worse it gets. I am totally new to tractor, all decals and such are worn off, no book on it, I dont even iknow how or where to check hydraulic fluid, what type it takes or anything ! Need some good help ! Thanks
/ Sd1540 B 3 point problems #6
Use a universal hydraulic /transmission fluid. First thing to check is lift cylinder orings. I can supply parts & manuals.
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
2844 (A58376)
2844 (A58376)
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59909)
2019 FREIGHTLINER...
2025 Anvil 12 ft S/A Enclosed Trailer (A61569)
2025 Anvil 12 ft...
