SAME Italian translation please
/ SAME Italian translation please #1
shanehobson
New Zealand
Ford 3000 (x2), Kubota F1900, Kubota B2150HST, IH434, Same Minitauro 60, Zetor 6745 (x2)
My SAME Minitauro 60 tractor has a lever to engage four wheel drive.
The two positions are labelled DIS and INN.
I can't work out which position is which, I thought I had it figured out, but based on some odd behaviour in the field yesterday, I suspect I've got it wrong.
The operators manual very helpfully points out there the 4WD lever is, but doesn't label the positions.
Thank you
/ SAME Italian translation please #2
Just a wild wild guess.... non-Italian type... DIS, disengage [ disengaramo clientele ] INN, engaged... [ Intesamo arivadeche clientele ]
/ SAME Italian translation please #4
/ SAME Italian translation please #5
The operators manual very helpfully points out there the 4WD lever is, but doesn't label the positions.Thank you
DISinnestare = Disconnect or Disengage
INNestare = Connect or Engage
Hope this helps
That was simple wasn't it. I tried google translate but was baffled by the Italian response. Thanks for your help everyone.
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
5' ROTARY MOWER (A60430)
5' ROTARY MOWER...
(2) UNUSED 31" X 10 MM EXCAVATOR TRACKS (A60432)
(2) UNUSED 31" X...
GMC 2500HD 4wd Service Truck (A61306)
GMC 2500HD 4wd...
3 BOTTOM TURN PLOW (A60430)
3 BOTTOM TURN PLOW...
HUSQVARNA RIDING MOWER 42IN DECK (A56859)
HUSQVARNA RIDING...
