SAME Italian translation please
/ SAME Italian translation please #1
shanehobson
New Zealand
Ford 3000 (x2), Kubota F1900, Kubota B2150HST, IH434, Same Minitauro 60, Zetor 6745 (x2)
My SAME Minitauro 60 tractor has a lever to engage four wheel drive.
The two positions are labelled DIS and INN.
I can't work out which position is which, I thought I had it figured out, but based on some odd behaviour in the field yesterday, I suspect I've got it wrong.
The operators manual very helpfully points out there the 4WD lever is, but doesn't label the positions.
Thank you
/ SAME Italian translation please #2
Just a wild wild guess.... non-Italian type... DIS, disengage [ disengaramo clientele ] INN, engaged... [ Intesamo arivadeche clientele ]
/ SAME Italian translation please #4
/ SAME Italian translation please #5
The operators manual very helpfully points out there the 4WD lever is, but doesn't label the positions.Thank you
DISinnestare = Disconnect or Disengage
INNestare = Connect or Engage
Hope this helps
That was simple wasn't it. I tried google translate but was baffled by the Italian response. Thanks for your help everyone.
3PT 10' Rolling Cultivator (A60462)
3PT 10' Rolling...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
1986 GMC C7000 Truck, VIN # 1GDM7D1G5GV542445 (A61165)
1986 GMC C7000...
CASE TR310B SKID STEER (A62129)
CASE TR310B SKID...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
KING CULTER FM-72-Y (A62130)
KING CULTER...
