SAME Italian translation please
/ SAME Italian translation please #1
shanehobson
New Zealand
Ford 3000 (x2), Kubota F1900, Kubota B2150HST, IH434, Same Minitauro 60, Zetor 6745 (x2)
My SAME Minitauro 60 tractor has a lever to engage four wheel drive.
The two positions are labelled DIS and INN.
I can't work out which position is which, I thought I had it figured out, but based on some odd behaviour in the field yesterday, I suspect I've got it wrong.
The operators manual very helpfully points out there the 4WD lever is, but doesn't label the positions.
Thank you
/ SAME Italian translation please #2
Just a wild wild guess.... non-Italian type... DIS, disengage [ disengaramo clientele ] INN, engaged... [ Intesamo arivadeche clientele ]
/ SAME Italian translation please #4
/ SAME Italian translation please #5
The operators manual very helpfully points out there the 4WD lever is, but doesn't label the positions.Thank you
DISinnestare = Disconnect or Disengage
INNestare = Connect or Engage
Hope this helps
That was simple wasn't it. I tried google translate but was baffled by the Italian response. Thanks for your help everyone.
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63118)
2023 New Holland...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
2024 JOHN DEERE 333P SKID STEER (A62129)
2024 JOHN DEERE...
