SAME Italian translation please
/ SAME Italian translation please #1
shanehobson
New Zealand
Ford 3000 (x2), Kubota F1900, Kubota B2150HST, IH434, Same Minitauro 60, Zetor 6745 (x2)
My SAME Minitauro 60 tractor has a lever to engage four wheel drive.
The two positions are labelled DIS and INN.
I can't work out which position is which, I thought I had it figured out, but based on some odd behaviour in the field yesterday, I suspect I've got it wrong.
The operators manual very helpfully points out there the 4WD lever is, but doesn't label the positions.
Thank you
/ SAME Italian translation please #2
Just a wild wild guess.... non-Italian type... DIS, disengage [ disengaramo clientele ] INN, engaged... [ Intesamo arivadeche clientele ]
/ SAME Italian translation please #4
/ SAME Italian translation please #5
The operators manual very helpfully points out there the 4WD lever is, but doesn't label the positions.Thank you
DISinnestare = Disconnect or Disengage
INNestare = Connect or Engage
Hope this helps
That was simple wasn't it. I tried google translate but was baffled by the Italian response. Thanks for your help everyone.
Wooden End Table (A61569)
Wooden End Table...
2017 Ford Transit 350 Passenger Van (A61568)
2017 Ford Transit...
2017 Ford Escape (A61569)
2017 Ford Escape...
DURA-CAST PRO-LICK TANK (A62131)
DURA-CAST PRO-LICK...
UNUSED RAYTREE REDM32-32" EXCAVATOR MULCHER (A62131)
UNUSED RAYTREE...
2023 John Deere 6R 145 Tractor (A63109)
2023 John Deere 6R...
