Buying Advice rotary cutter
/ rotary cutter #1
gravelman
Platinum Member
NH
Kubota 2650
hi folks..gravelman here..im thinking of buying a Kodiak 5' HD rotary cutter... any advice or info out there. I need an easy to change blade cutter...getting too old to be climbing under stuff. thanks
/ rotary cutter #2
Woods......... How much is the Kodiak 5 footer
/ rotary cutter #4
What dealer ?
/ rotary cutter
He is an independent used equip dealer in Mass... he has a mower will few hours on it... im not sure what he wants for it and i don't know..yet, how much a new one is..
/ rotary cutter #6
My woods BB60 was 2100.00 or 2200.00 I'd have to look it up.... woods BB60.jpg
/ rotary cutter #8
im guessing it will be under $2000 im just wondering how easy it is to change blades...
Kodiak makes them for Mahindra.... slip clutch ?
/ rotary cutter #9
Can't see a removable plate cover on those mowers..... to undo bolts from the top.....
/ rotary cutter #10
Kodiak uses a 1 1/4 bolt to hold each blade on. The nut's on the top and there is an access hole in the deck. I can't find a torque spec in the manual but it's probably lots.
Someone posted some pics a while back of the Woods blade fixture that looks much easier to deal with.
/ rotary cutter #11
I did on the woods.....
/ rotary cutter #12
/ rotary cutter
Ok got it all thanks much
/ rotary cutter
one way or another it looks like a two man job no matter whos mower it is
/ rotary cutter #15
There should be a way to do it with one person. Perhaps strapping the blade to be removed to the center carrier before using an impact wrench on the nut.
/ rotary cutter
Yes i have done it by myself as all of you probably have...one extra pair of hands to start the top nut is always helpful.
/ rotary cutter #17
Call Chappell tractor and get a price on the woods cutter...can't hurt..........
/ rotary cutter
ok i can do that...i have a feeling Woods is on the pricey side...im not going to be using this much... just some choppin now and then so im kinda leaning toward cheap....
/ rotary cutter #19
Pay once cry once..........:laughing:
/ rotary cutter
Believe me...truer words were never spoken...i usually live by that but im gettn a bit cheap in my old age... thanks for that tho...it is VERY true
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
2022 EZ-GO ELITE...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
