Buying Advice rotary cutter
/ rotary cutter #1
gravelman
NH
Kubota 2650
hi folks..gravelman here..im thinking of buying a Kodiak 5' HD rotary cutter... any advice or info out there. I need an easy to change blade cutter...getting too old to be climbing under stuff. thanks
/ rotary cutter #2
Woods......... How much is the Kodiak 5 footer
/ rotary cutter #4
What dealer ?
/ rotary cutter
He is an independent used equip dealer in Mass... he has a mower will few hours on it... im not sure what he wants for it and i don't know..yet, how much a new one is..
/ rotary cutter #6
My woods BB60 was 2100.00 or 2200.00 I'd have to look it up.... woods BB60.jpg
/ rotary cutter #8
im guessing it will be under $2000 im just wondering how easy it is to change blades...
Kodiak makes them for Mahindra.... slip clutch ?
/ rotary cutter #9
Can't see a removable plate cover on those mowers..... to undo bolts from the top.....
/ rotary cutter #10
Kodiak uses a 1 1/4 bolt to hold each blade on. The nut's on the top and there is an access hole in the deck. I can't find a torque spec in the manual but it's probably lots.
Someone posted some pics a while back of the Woods blade fixture that looks much easier to deal with.
/ rotary cutter #11
I did on the woods.....
/ rotary cutter #12
/ rotary cutter
Ok got it all thanks much
/ rotary cutter
one way or another it looks like a two man job no matter whos mower it is
/ rotary cutter #15
There should be a way to do it with one person. Perhaps strapping the blade to be removed to the center carrier before using an impact wrench on the nut.
/ rotary cutter
Yes i have done it by myself as all of you probably have...one extra pair of hands to start the top nut is always helpful.
/ rotary cutter #17
Call Chappell tractor and get a price on the woods cutter...can't hurt..........
/ rotary cutter
ok i can do that...i have a feeling Woods is on the pricey side...im not going to be using this much... just some choppin now and then so im kinda leaning toward cheap....
/ rotary cutter #19
Pay once cry once..........:laughing:
/ rotary cutter
Believe me...truer words were never spoken...i usually live by that but im gettn a bit cheap in my old age... thanks for that tho...it is VERY true
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
Aluminum Set of Tool Boxes (A62613)
Aluminum Set of...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
Kuhn GMD 600 (A64127)
Can Am Defender (A63688)
Can Am Defender...
2015 Bobcat E42 (A64126)
2015 Bobcat E42...
