Replacement engine for 336D
/ Replacement engine for 336D #11
I'm not sure about a replacement engine or what they cost. But, I have a 336D with a hoe and loader and other equipment and have used it heavily for several years. Great machine. Worth a little trouble ifthe price is right. does it have weell weights??
Good luck
joe
/ Replacement engine for 336D #12
Just a note about a backhoe on the 336d. I have a Woods 750 3pt backhoe on my 336d but I have a Yanmar subframe unit. It is pretty easy to take on and off and does not stress the tractor frame as much I am told.
/ Replacement engine for 336D #13
Looks like there are a few of us interested,if someone locates it, I would be int in partnering up, for the right price...
I am in CT,near the Mass Border
/ Replacement engine for 336D #14
I'm up for partnering up for a few parts of it. I could use a loader and a couple of transmission gears. If the price is right, it could be parted between a few for a decent price each.
/ Replacement engine for 336D #15
The 336D is a really nice tractor. It used the Yanmar 3T84A-N engine. The hours could be 1850 too - I beleive that model has a 3 digit hour meter. If you suspect water in there I would try to tear the top open or atleast remove the compression using the comp release and see if you can turn the engine with a long ratchet on the crank nut. Try Hoyes - you can look up the rebuild kits pricing and I believe there are a few sites around that sell engines - you just need to find that engine though... I have never used these guys for used parts but I had them saved in my notebook under just in case: wkytp.com
southern-global.com
Where are you located? The backhoe is worth a few bucks...I know I for one would be interested...
I have used wkytp.com noted above very satisfactorily .. gotta decent hood for an L285 Kubota here .. 1000% better than what was on it, and very competitive frieght charge to Calif. Best to call .. they seem to have alot of stuff moving in and out .. web lisings may not be always current .. jmho.
As to Yamar, I have 3 Komatsu's here with Yanmar engines .. for Komatsu and Deere .. etc .. expect No help from YanmarUsa. I need help on fixing or replacing a 3d84-1c in my loader (WA30-2) and the Komatsu pubs are of little help. So, if you buy anthing engined with Yanmar .. grab up any and all the docs you can. My dozer and excavator always start right up .. the loader is just tired I guese.
On my 3 Yanmars (Komatsu's) .. there is NO compression release that I can find either! What's with that? Kubota has .. Jinma has.
OK guys, sounds like there's some interest in this tractor, here's the link. The seller is shooting for the moon at 8K, he's interested in an offer. It looks to be low hours, 800 or so on the gauge which I suspect is right. I'd be very surprised if the owner had done any maintenance at all on it.
Yanmar Diesel 336D Power Shift Tractor
Good luck. Caveat emptor
Chuck
/ Replacement engine for 336D #17
Bah! That's not worth $8000 with a running engine!
/ Replacement engine for 336D #19
Chuck
If you subtract the value of the backhoe and FEL, he's not asking very much for the tractor, brush hog, and box blade. Have you looked at the cost of backhoes?
/ Replacement engine for 336D #20
I guess I missed where the engine is bad too the add doesn't say that fact it says all in working order? Pics would help the guys cause but thats jmo.
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
2008 Scag STT52V-27CH 52in Zero Turn Mower (A59228)
2008 Scag...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
2004 Mack CV713 Granite Fuel and Lube Truck (A59230)
2004 Mack CV713...
