Replacement engine for 336D
/ Replacement engine for 336D #1
skypoke
I'm looking at a 336D that has a motor with unknown problems. What is known is that the radiator is dry, it won't turn over (but is not locked solid, the crank moves a bit with starter). The tractor is relatively low hours, 850, and appears to be in pretty good shape other than motor.
Could be blown head gasket, cyls full of water...bent rods...cracked block...or could be the starter is just bad. It's a pig in a poke but with a lot of implements including hoe, loader etc., and the owner is looking for an offer. He states that he "thinks" the tractor was overheated once. I do my own mechanics and could do repairs up to a rebuild but i'm thinking the best option would be to try to tack down a running or rebuilt engine and base my offer on that worst case scenario.
I can do limited inspection, possibly including pulling injectors. Doesn't appear to be any way of getting to the front crank nut without pulling radiator, probably not an option for a pre buy. It rarely gets cold enough to freeze/crack blocks here but it does happen occasionally. Would a crack be readily apparent? Do these engines have freeze plugs. Any ideas on things to check? Does anyone know a source for used engines...are they hard to find....rebuild units anywhere?
I'm willing to take a chance on condition of the rest of the unit. Would appreciate you guys thoughts on this. Any idea of what a frame mount backhoe (yanmar brand) would be worth on the open market? I don't really need one and it might help reduce cost to buy the pkg and sell the hoe.
Thanks,
Chuck
/ Replacement engine for 336D #2
The 336D is a really nice tractor. It used the Yanmar 3T84A-N engine. The hours could be 1850 too - I beleive that model has a 3 digit hour meter. If you suspect water in there I would try to tear the top open or atleast remove the compression using the comp release and see if you can turn the engine with a long ratchet on the crank nut. Try Hoyes - you can look up the rebuild kits pricing and I believe there are a few sites around that sell engines - you just need to find that engine though... I have never used these guys for used parts but I had them saved in my notebook under just in case: wkytp.com
southern-global.com
Where are you located? The backhoe is worth a few bucks...I know I for one would be interested...
/ Replacement engine for 336D #3
I would try and fix it first if it turns out to be something simple like a head gasket and all you have to do is re-ring it that would be a cheap repair.
With that said:
I would not trust the rods not being bent if its got water in any of the cyls have them checked for straightness at a minimum if the bend is not obvious dont trust your eyes get a pro to look everything over.
/ Replacement engine for 336D #4
I cannot speak for all years but my 336d has 1575 hours on it so my meter will register to 9999 hours.
The radiator is prone to clogging if mowing occurs in heavy seedy stuff. Overheating is a possiblity.
This is sounding encouraging, I appreciate the help. Can you tell me where the compression release is? I assume this holds open the valves? I've got to admit, I'm impressed with the general looks and build of the tractor, and it's awakened my desire to make stuff run.
What, other than head warpage and gasket blowing, effect would overheat have on the motor?
I'm going to take a breaker bar over and see if I can turn the engine. Anyone know what size socket fits the front crank nut? If it isn't locked I'll most likely take a chance and buy it. The backhoe is a lightly used Yanmar brand, it does not mount on the 3 point though it does use an external pto pump. Tractor and hoe are located in Tx. I'd appreciate it if anyone has a realistic idea of what the hoe is worth, that'll give me some nego room. I truly don't need it.
Chuck
Once again, thanks for the help and keep the ideas comin.
Chuck
/ Replacement engine for 336D #6
If it's the same guy I emailed back and forth, he said it threw a rod. This guy was in Waco, TX.
I'd hate for it to be the same guy simply changing his story in order to dump the tractor on someone unable to tell the difference.
You may be hard pressed to find a replacement engine for even a remotely decent price, if at all. Used parts for these tend to run 50-80% of new price and the new prices are crazy high. Don't mean to pee on your parade, I know how much I tend to trick myself into thinking things aren't that bad when I want something bad enough, only to learn an expensive lesson.
On a side note, I have a 336D and it is a nice tractor. It'd be nice to have another 336D owner in here, as we're pretty underrepresented :). I'd prefer to not see any posts from people saying they were taken for a ride, though.
/ Replacement engine for 336D #7
$500.00 for the old not needed hoe send it cod it's sold!
Car Doc,
The backhoe is on its way, air freight collect. Seriously, after doing some parts looking and thinking on it a bit, I've decided to give this tractor a pass. There are just too many good deals on later model tractors to undertake a project of unknown magnitude.
I want to thank everyone for taking the time to advise me.
Thanks,
Chuck
/ Replacement engine for 336D #9
If you are not going to grab it maybe you could post information in case someone else is interested.
Chris
/ Replacement engine for 336D #10
Chris
Ditto on this.
You also never mentioned what he was willing to take for it. Its tough to say if something is worth it without being able to do the math.
/ Replacement engine for 336D #11
I'm not sure about a replacement engine or what they cost. But, I have a 336D with a hoe and loader and other equipment and have used it heavily for several years. Great machine. Worth a little trouble ifthe price is right. does it have weell weights??
Good luck
joe
/ Replacement engine for 336D #12
Just a note about a backhoe on the 336d. I have a Woods 750 3pt backhoe on my 336d but I have a Yanmar subframe unit. It is pretty easy to take on and off and does not stress the tractor frame as much I am told.
/ Replacement engine for 336D #13
Looks like there are a few of us interested,if someone locates it, I would be int in partnering up, for the right price...
I am in CT,near the Mass Border
/ Replacement engine for 336D #14
I'm up for partnering up for a few parts of it. I could use a loader and a couple of transmission gears. If the price is right, it could be parted between a few for a decent price each.
/ Replacement engine for 336D #15
southern-global.com
I have used wkytp.com noted above very satisfactorily .. gotta decent hood for an L285 Kubota here .. 1000% better than what was on it, and very competitive frieght charge to Calif. Best to call .. they seem to have alot of stuff moving in and out .. web lisings may not be always current .. jmho.
As to Yamar, I have 3 Komatsu's here with Yanmar engines .. for Komatsu and Deere .. etc .. expect No help from YanmarUsa. I need help on fixing or replacing a 3d84-1c in my loader (WA30-2) and the Komatsu pubs are of little help. So, if you buy anthing engined with Yanmar .. grab up any and all the docs you can. My dozer and excavator always start right up .. the loader is just tired I guese.
On my 3 Yanmars (Komatsu's) .. there is NO compression release that I can find either! What's with that? Kubota has .. Jinma has.
OK guys, sounds like there's some interest in this tractor, here's the link. The seller is shooting for the moon at 8K, he's interested in an offer. It looks to be low hours, 800 or so on the gauge which I suspect is right. I'd be very surprised if the owner had done any maintenance at all on it.
Yanmar Diesel 336D Power Shift Tractor
Good luck. Caveat emptor
Chuck
/ Replacement engine for 336D #17
Bah! That's not worth $8000 with a running engine!
/ Replacement engine for 336D #19
Chuck
If you subtract the value of the backhoe and FEL, he's not asking very much for the tractor, brush hog, and box blade. Have you looked at the cost of backhoes?
/ Replacement engine for 336D #20
I guess I missed where the engine is bad too the add doesn't say that fact it says all in working order? Pics would help the guys cause but thats jmo.
PORTA POTTY (A67714)
For Sale - Brush Hog - Woods RCC42 rotary cutter
For Sale - Brush...
2016 MAGNUM  MLT6S (A68842)
2016 MAGNUM MLT6S...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A64556)
2021 Mercedes-Benz...
2006 International 4200 2,000 Gallon Water Truck (A64553)
2006 International...
