Removing Wallpaper?
/ Removing Wallpaper?
Thanks Phil, I was trying to find out if the Wallpaper Removers work. Have a great day. Kent
/ Removing Wallpaper? #22
WOW, Real nice room.
WOW, real bad wallpaper. /w3tcompact/icons/smile.gif
/ Removing Wallpaper? #24
Yikes, talk about clashing with the stone pattern in the chimney! Just think, when someone else worked so hard to get that wallpaper up there, stood back and admired their handiwork. Makes you wonder, doesn't it? /w3tcompact/icons/laugh.gif
/ Removing Wallpaper? #25
A quick followup on this wallpaper thread...I didn't start the thread, but was coincidentally working on a room.
We ended up buying a wagner steamer at Home depot for about $50, instead of renting one for one day at $30 (that seemed like a no-brainer to me).
Anyway, paper is all stripped, and I have been meticulously scrubbing the walls trying to get every last spec of glue residue off the wall. We will be painting this when we are done.
Question is: How important is it to get every spec of glue off the wall before painting? Is the goal to get the glue off because it will somehow bleed thru the paint? or should we really just be making sure that the wall is smooth enough?
Thanks guys...probably too late for this room, but I have another 4-5 to go after this one so the recommendations will not go to waste.
Also, from a painting point of view, how many coats does one normally need for interior painting? I am guess 1-2 at most..
Lastly, would a pro paint the woodwork before the walls or the walls before the woodwork?
/ Removing Wallpaper? #26
Ejb, After you strip as much glue as possible, prime the walls with something like Kilz or Bin. This will seal any residue you missed and provide a better base for the finish paint. Depending on color it will take 1 or 2 finish coats. I always seem to end up doing 2 coats. The pro’s will generally paint the walls and then the trim. Even being careful there will be some splatter with a roller that ends up on the trim.
MarkV
case 370 glass door never installed (A61307)
case 370 glass...
2025 Swict 66in Bucket Skid Steer Attachment (A59228)
2025 Swict 66in...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
