Radiator repair
/ Radiator repair #21
Don't forget to replace the radiator cap.
/ Radiator repair
I got the rad cab and air filter installed today and managed to put 3 hours on the tractor with no problems, my home radiator repair has held up so far, I'm sure the radiator cap was in fact the culprit and now with the radiator flushed out and new water/antifreeze installed It'll be good to go for a while longer, Now I need to work on getting some new tires so i can get started on some Fall bush hogging,
/ Radiator repair #24
Well it was obvious by the pics you did a good job in the frame and now get it on a bench so a real good job can be done Id say good for you well done saved some money! :thumbsup:
Scag 36 Advantage (A64912)
Scag 36 Advantage...
VICON ROTOFLOW SPREADER (A63291)
VICON ROTOFLOW...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
Ez-Go Freedom Electric Golf Cart (A64912)
Ez-Go Freedom...
2017 Peterbilt 320 New Way 20ASL 20yd Side Loader Garbage Truck (A66736)
2017 Peterbilt 320...
2006 MACK CHN613 (INOPERABLE) (A67714)
2006 MACK CHN613...
