Hydraulic oil leak / critters and vent tubes crazy fix
   / Hydraulic oil leak / critters and vent tubes crazy fix #1
livemusic
Bronze Member
Louisiana, USA
Mahindra 5010
I pass along so it might help someone, seems kind of unusual.
I bought my Mahindra 5010 used. After using it awhile, I started noticing some kind of fluid on the ground after I moved the tractor from where it was parked in the pasture the night before. But it seemed to be under the wheels, not the main tractor. I surmised that the tires must have some kind of ballast and it was leaking out. I contacted the former owner and he said no. I finally deduced that this was hydraulic oil. I also could see that it seemed to be coming from around the wheel rims.
Long story short is that I stopped into a small tractor dealer shop to buy some maintenance supplies for the tractor and spoke to the owner and chief mechanic, told him about this leak. At that point, I was thinking that there are axle seals that must be leaking. And said, "What are the odds that both the left and right seals would start leaking at the exact same time on this ten year old tractor?" His reply was that he felt that the odds were pretty low and his advice was... he said there could be a vent tube somewhere around or atop the transmission and if such tube is clogged up, it could cause pressure to build and the oil could leak out around the rims.
Lo and behold, I finally found such a vent tube, about a 1 foot piece of rubber tubing atop the transmission. Took it off and it WAS plugged up. Whacked on it with my fist and dirt and 'stuff' started falling out. I surmise that a dirt dobber (mud dauber wasp) had built a nest in there and it was totally plugged. Cleaned the tube. I ran the tractor for ten hours recently and no problems.
I tell ya, dirt dobbers and ants and mud-building critters wreak havoc on me. I had this same thing happen last fall on an old outboard motor that was not not peeing water. I finally found that the water line exhaust tube was plugged up with dirt, hardened mud. Now, this tube is SMALL; I couldn't believe a critter had built a nest in such a small tube opening but that is my only explanation. A common dirt dobber wasp is too big to even get in there. Had to be a small one or ants or some other bug. Cleaned it out and the motor 'peed' just fine after that.
This is a hat tip to an honest dealer/mechanic. It's the second time he has given me a tip on something and he was spot on. The heck of it is, I am not a mechanic, I do maintenance and any repairs that I can figure out how to do and if I had not found that vent tube, I would have had to take the tractor to a dealer and been at their mercy. They could have charged me a LOT and we all hate to have to cough up hard-earned big bux on repairs. I don't know how much it costs to replace seals in both axles but I'm sure it wouldn't be pocket change. I might could have made such a repair, not sure but I am not really set up with heavy repair equipment to handle stuff like this and work alone a lot. It is nice to find an honest mechanic/dealer.
Crazy critters just doing their thing. Makes me wonder should I place some kind of cap over the end of such orifice openings on my equipment when not in use! Would have to remember to remove before running it!
I also wonder if such vent tubes are common on other makes of tractors. Manufacturers should plan on critter stuff!
   / Hydraulic oil leak / critters and vent tubes crazy fix #2
I also wonder if such vent tubes are common on other makes of tractors. Manufacturers should plan on critter Could you put a small piece of rolled up screen in the end of the tube to keep the insects out?
Could you put a small piece of rolled up screen material in the end of the tube to prevent insects from getting in?
That is a good idea; what comes to mind is hoping it would allow enough venting and not build pressure in the system.
   / Hydraulic oil leak / critters and vent tubes crazy fix #4
That is a good idea; what comes to mind is hoping it would allow enough venting and build pressure in the system.
Or maybe just bend it around the outside and use a wire twist tie or zip tie to keep it in place.
   / Hydraulic oil leak / critters and vent tubes crazy fix #5
I’ve heard of people using clear plastic gas filters on truck axle vent. might work here.
Alternate View 2 for Prime Line Fuel Filter
You mean they use it for this very problem or something else? leaving the whole filter intact, as is? I first thought this is a great solution but then recalled the boat motor pee tube; the opening in it is very small diameter and whatever critter it was got in there and sealed it with dirt.
   / Hydraulic oil leak / critters and vent tubes crazy fix #7
People that do a lot of 4 wheeling in mud, stream crossings run a length of tubing from the axle vent to a higher point on the truck and stick the filter in the end to keep dirt,dust bugs etc out. Pressure in an axle or gear box goes both positive and negative as temperatures change. So debris can get sucked in.
   / Hydraulic oil leak / critters and vent tubes crazy fix #8
Just have to check and make sure insects don't clog up the filter opening but easy to replace.
   / Hydraulic oil leak / critters and vent tubes crazy fix #9
I've had the same (type) of issue...
I used an old chainsaw fuel screen (inside the tank) to prevent this. Another odd substitute would be the air-stone from an aquarium, for in/out pressure relief without the bugs having a hole to plug.
I remember the old Toyota trucks had an axle vent that was spring loaded to relieve internal pressure and still keep water and mud out.
Boat fuel tank vent being plugged by bugs was something I learned growing up.
2006 Ford F-650 Terex Hi-Ranger TL37P 37ft. Bucket Truck (A55852)
2006 Ford F-650...
UNUSED FUTURE LS43 HYD WOOD SPLITTER (A57193)
UNUSED FUTURE LS43...
Electric Mobility Scooter (A55853)
Electric Mobility...
Massey Ferguson 9250 (A55315)
Massey Ferguson...
2018 PETERBILT 567 FLATBED DUMP (A57880)
2018 PETERBILT 567...
2025 AGT STSD10 (A56469)
2025 AGT STSD10...
