Radiator Pressure
/ Radiator Pressure
I will flush it out tomorrow and see what happens. I still can't figure out why it doesn't run hot.
Eugene
/ Radiator Pressure
OK guys, you'll never believe this. I finally flushed out the cooling system. The radiator was not stopped up. The block was, with rust. Looks like someone ran straight water in it before me. When the rust broke loose I had full flow. I let it run in the driveway for 30 minutes with the overflow hose out of the bottle. Not a drop. Put the hose back in the bottle and instantly started blowing coolant out of the vent hole. Took the hose back out, it stopped. I did this repeatedly with the same results. I can touch the block bare handed and not get burned. Is my tractor haunted?
Eugene
/ Radiator Pressure
Eugene
/ Radiator Pressure #15
"Put the hose back in the bottle and instantly started blowing coolant out of the vent hole."
What vent hole are you referring to? The only vent I am aware of should have the overflow tube attached to it.
/ Radiator Pressure #16
/ Radiator Pressure
The vent hole is in the cap of the overflow bottle.
Eugene
/ Radiator Pressure
Eugene
/ Radiator Pressure #19
Assuming your 16# cap is good, sounds like you may be back to a bad head gasket. Something is creating high pressure in your system.
/ Radiator Pressure #20
2019 Deere 35G (A53317)
2019 Deere 35G...
5004 (A55851)
5004 (A55851)
10in Digging Tooth Bucket Excavator Attachment (A60352)
10in Digging Tooth...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
PUMP (A60736)
PUMP (A60736)
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
