Radiator Pressure
/ Radiator Pressure #21
My overflow bottle has the full mark at about the 75% mark. Is yours full to the top? Do you see any bubbles coming out of the overflow tube? With the overflow bottle not full full to the top, when the tractor runs does it fill up right away to the top?
Jerry
/ Radiator Pressure #22
Jerry
/ Radiator Pressure
Nothing comes out of the overflow tube until I insert it down in the coolant in the overflow bottle. I can have the bottle filled half way up and it fills up instantly. I pull the tube out and the flow from the tube stops immediately.
Eugene
/ Radiator Pressure
Eugene
/ Radiator Pressure #25
"Nothing comes out of the overflow tube until I insert it down in the coolant in the overflow bottle. I can have the bottle filled half way up and it fills up instantly. I pull the tube out and the flow from the tube stops immediately.
I'm going to have to give up on that one. That makes no sense to me, unless it's magic.
/ Radiator Pressure #26
/ Radiator Pressure
Bruce,
I don't understand your question. The pressure doesn't start until it has warmed up but there must not be a thermostat in it because you can touch the block and put your finger in the radiator and it's just lukewarm.
Eugene
/ Radiator Pressure
Bruce,
Eugene
/ Radiator Pressure #33
I would think that if you have no pressure with the engine cold, that would rule out a head gasket problem.
/ Radiator Pressure #34
/ Radiator Pressure #35
I have heard of 2cyl Yanmars cracking between the cylinders. It would get larger as it warmed up. If you put the overflow hose in a cup and it bubbles or blows the water out that tells you it is getting pressure in the cooling system from compression rather than heat expansion. Also rust is a sign of air being introduced into a sealed system. Every cracked block or gasket I have dealt with had very rusty water in the system.
/ Radiator Pressure #36
/ Radiator Pressure #37
AHA!! I'll bet it's blowing air, (combustion gas), out the overflow tube at all times and blowing bubbles when you insert it into the bottle.
/ Radiator Pressure #38
/ Radiator Pressure
It doesn't blow any bubbles, it blows coolant. I admit that everything I know about diesels I learned on this forum but I have been an auto mechanic for 34 years. I know that when you have a blown head gasket or a cracked head one of three things happen. It either is burning coolant through the exhaust, has oil in the antifreeze or has antifreeze in the oil. None of these three conditions exist. I'm not going to worry about it any more. The tractor runs like a top and it's not overheating. Thanks for everybody's help. I guess evey once in a while the unexplainable happens and this is one of those times.
Eugene
/ Radiator Pressure
Eugene
2019 K&K Trailer, VIN # 1K9PE2027KA175461 (A65563)
2019 K&K Trailer...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
2022 YANMAR VIO80-1A EXCAVATOR (A63276)
2022 YANMAR...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
Landhonor 24" Semi-Automatic Tire Changer (A62679)
Landhonor 24"...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
