radiator cap
/ radiator cap #1
vbstang
yanmar 1500D
Hey does any one know the correct pressure for the radiator cap for a ym 1500d.
Thanks,
Vernon
/ radiator cap #3
I believe most all of the older ym series use a 13 lb cap. My 220/226 manual says cap should maintain 11-15psi. The cap on my ym2002d is a 13psi. If you browse thru Hoye's parts you will see most all models use the same cap. After more research I do believe the Hoye cap may be a 7lb cap. Aaron may want to confirm that and then again he may not. I do know for certain there is lots of info out there giving 13 or 7lb caps. I certainly can't argue with my service manual so I will stick with the 13lb cap on my ym2002d.
/ radiator cap #4
I also use a 13 on my 1610d,per manual spec. russ
2021 Bobcat T66 R-Series (A64911)
2021 Bobcat T66...
2014 Deere 324J (A64911)
2014 Deere 324J...
218799 (A65057)
218799 (A65057)
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
1991 American Pride APE2-6 Electric Cart (A66738)
1991 American...
2021 Ford Explorer SUV (A66738)
2021 Ford Explorer...
