radiator cap
/ radiator cap #1
vbstang
yanmar 1500D
Hey does any one know the correct pressure for the radiator cap for a ym 1500d.
Thanks,
Vernon
/ radiator cap #3
I believe most all of the older ym series use a 13 lb cap. My 220/226 manual says cap should maintain 11-15psi. The cap on my ym2002d is a 13psi. If you browse thru Hoye's parts you will see most all models use the same cap. After more research I do believe the Hoye cap may be a 7lb cap. Aaron may want to confirm that and then again he may not. I do know for certain there is lots of info out there giving 13 or 7lb caps. I certainly can't argue with my service manual so I will stick with the 13lb cap on my ym2002d.
/ radiator cap #4
I also use a 13 on my 1610d,per manual spec. russ
HANDICAP PORTA POTTY (A68842)
HANDICAP PORTA...
2018 GRASSHOPPER 900D MOWER (A66091)
2018 GRASSHOPPER...
QA Plate (A64912)
QA Plate (A64912)
2018 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
CAT 345CL Track Adjusters (A68134)
CAT 345CL Track...
6 wheels to fit a CAT 120G (A68134)
6 wheels to fit a...
