Quick-Tatch disassembly help
/ Quick-Tatch disassembly help #1
rtm038
New Jersey
Hey all,
I need to remove the pivot/push beam (#30) from the A-frame (#27) on a front Quick-Tatch set-up. So far I've removed the main pivot bolt (#33 below), but can't get the bushing (#32) out. Does anyone know how to get this bushing out?
Thanks
Ryan
/ Quick-Tatch disassembly help #2
No clue on that one! Is it damaged?
Figured it out. I needed to hit the backside of the push beam with a mallet a few times to get it slide off the A-frame.
Ryan
/ Quick-Tatch disassembly help #4
Are you rebuilding it to tighten it up a bit? Mine's sure sloppy and that thought has crossed my mind.
/ Quick-Tatch disassembly help #5
With the bolt removed and item 27 is separated from item 30 you should be able to drive out the bushing or preferably, press it out with a hydraulic press.
/ Quick-Tatch disassembly help #6
That was 9 years ago...hope he fixed it by now LOL.
Yeah I got it fixed.......a long time ago LOL
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
2020 Deere 544L (A60462)
2020 Deere 544L...
2021 Ford F-150 4x4 Single Cab Pickup Truck (A61573)
2021 Ford F-150...
2016 Ford Explorer (A59231)
2016 Ford Explorer...
2022 EZ-GO ELITE...
