Quick-Tatch disassembly help
/ Quick-Tatch disassembly help #1
rtm038
New Jersey
Hey all,
I need to remove the pivot/push beam (#30) from the A-frame (#27) on a front Quick-Tatch set-up. So far I've removed the main pivot bolt (#33 below), but can't get the bushing (#32) out. Does anyone know how to get this bushing out?
Thanks
Ryan
/ Quick-Tatch disassembly help #2
No clue on that one! Is it damaged?
Figured it out. I needed to hit the backside of the push beam with a mallet a few times to get it slide off the A-frame.
Ryan
/ Quick-Tatch disassembly help #4
Are you rebuilding it to tighten it up a bit? Mine's sure sloppy and that thought has crossed my mind.
/ Quick-Tatch disassembly help #5
With the bolt removed and item 27 is separated from item 30 you should be able to drive out the bushing or preferably, press it out with a hydraulic press.
/ Quick-Tatch disassembly help #6
That was 9 years ago...hope he fixed it by now LOL.
Yeah I got it fixed.......a long time ago LOL
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A59911)
2001 FREIGHTLINER...
2017 Nissan Pathfinder SUV (A61574)
2017 Nissan...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
2018 Dodge 5500 Bucket Truck 4WD (A63689)
2018 Dodge 5500...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Lucknow 360 Feed Wagon (A63688)
Lucknow 360 Feed...
