Quick-Tatch disassembly help
/ Quick-Tatch disassembly help #1
rtm038
New Jersey
Hey all,
I need to remove the pivot/push beam (#30) from the A-frame (#27) on a front Quick-Tatch set-up. So far I've removed the main pivot bolt (#33 below), but can't get the bushing (#32) out. Does anyone know how to get this bushing out?
Thanks
Ryan
/ Quick-Tatch disassembly help #2
No clue on that one! Is it damaged?
Figured it out. I needed to hit the backside of the push beam with a mallet a few times to get it slide off the A-frame.
Ryan
/ Quick-Tatch disassembly help #4
Are you rebuilding it to tighten it up a bit? Mine's sure sloppy and that thought has crossed my mind.
/ Quick-Tatch disassembly help #5
With the bolt removed and item 27 is separated from item 30 you should be able to drive out the bushing or preferably, press it out with a hydraulic press.
/ Quick-Tatch disassembly help #6
That was 9 years ago...hope he fixed it by now LOL.
Yeah I got it fixed.......a long time ago LOL
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A60352)
Paladin 12in...
2017 Load Trail 3.5 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
JOHN DEERE 6140M TRACTOR (A62130)
JOHN DEERE 6140M...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
Wacker Neuson AR14H (A60462)
Wacker Neuson...
