Quick Hitch
/ Quick Hitch #1
dinoedwards
kubota
Is it true that SpeeCo is the only Cat1 QH not requiring bushings?
Can be had at Tractor Supply for $170.
/ Quick Hitch #3
I have the speeco quick hitch, got it on amazon and it works fine.
The only thing I need to figure out with it is my brush hog has a rotating pin on top that can pop out of the top hook. If anyone has any solutions, I'm all ears. I'm about ready to weld it in place so it doesn't rotate.
/ Quick Hitch #4
"Linkage" on brush hog is not adjusted correctly.....
/ Quick Hitch #5
The only "attachment" I use that would really benefit from a quick hitch is the concrete ballast block. That thing is a royal PIA to get hitched. Mostly cause I don't have any level spots to drop it.
/ Quick Hitch #6
You don't need those expensive bushings with the enlarged end. The simple tubular ones work OK, even if doubled up on the implement pin to fit the hitch.
Bruce
/ Quick Hitch #8
Instead of using the top hook, I use about 16 inches of chain with hooks. I shorten the link between the tractor and the top of the QH. In place of the top hook, I make a chain loop around the QH's top hook area and back to the mower. When backing up to attach the mower only the lower hooks have to be aligned precisely.
This chain still allows lifting the mower, and the slack works better for crossing low spots where there can be an extreme angle between the tractor and mower.
For parking the mower, that chain is used to suspend the driveline at the approximate height needed to hook it up next time, and keep it out of the dirt.
/ Quick Hitch #9
Bruce
I run with no bushings. Hitting so many gopher mounds my rough mowing doesn't have, or need, precision.
20 years of this and I don't see any notable wear on the QH or the mower's lower pins.
/ Quick Hitch #10
Maybe this will give you an idea.
Bruce
/ Quick Hitch #12
Can't find the photo of my top chain but I found this. I replaced the hook bolts with removable pins because my implements from various eras have different upper hook heights.
The photo also shows how I adapted the trailer ball crossbar to keep the ball upright. Those small tabs are welded to adapter sleeves then are bolted to the bar and to the ends of the pins. I thought the tabs would get twisted after a while but no.
kimg1766rqh-toplinkpins-jpg.475243
/ Quick Hitch #13
Only the Speeco "E"-Hitch does not require bushings on the lower pins, you still need them on the top link connection. Good Works Tractors now has a version like that too.
/ Quick Hitch #14
Yep. They're pretty proud of it too at $329. I got mine at Harbor Freight about 15 years ago for something like $79 or $89. Mine doesn't require bushings either. I tack welded strips of metal into the lower hooks. Easy to replace if they ever wear out, but they haven't yet. And that was long before anyone said you had to have bushings for all your implements. :ROFLMAO:
/ Quick Hitch #15
I like my chain in place of that #3 link. It allows more slack for uneven ground, and is easier to hook up.
I use a stirrup between the quick hitch and my upper link cylinder. This accomplishes the same thing. And it works for my mowers and the back blade. The picture shows the 3PH in the raised position, so it doesn't depict all the free movement when at mowing/working height. I've used this setup for about 15 years.
The white staining is dry-lube. :whistle:
/ Quick Hitch #16
For those running w/o bushings, or bushings lacking the larger bulb at the end, any issues with side-to-side play allowing the implement to fall out of the quick hitch?
I actually like the bushing design, and the non-OEM versions are cheap enough at TSC that I don't mind buying a pair for each implement. The convenience of my iMatch quick hitch is well worth that cost of admission.
It's funny that the cost of bushings thru Deere actually had me hold off on getting a quick hitch, when I first ordered the latest tractor. But then once I saw they were one-third of OEM price at TSC, I jumped in with both feet.
/ Quick Hitch #17
I use a QH for everything but still find it convenient to have the implements level when hooking up. For the stuff that's outside, I have "landing spots" that I have level with concrete blocks or 4x4's.
/ Quick Hitch
Good info! I have a rake, box blade and rotary cutter.
Concern is cutter.
My RC5 may need a clevis/stirrup, see photo. Thoughts?
/ Quick Hitch #20
Thanks @dinoedwards for the timely thread. I am more interested than ever in getting myself set up with a quick hitch. But the idea of adding bushings to all my equipment sounded daunting.
So then I found the good works tractor page and was intrigued by both the speeCo and their own quick hitch designs. But they want $300 for this same SpeeCo hitch, $170 sounds a lot better!
Trench Box (A64553)
Trench Box (A64553)
2007 JLG 600HJ 60ft 4x4 Articulating Boom Lift (A64553)
2007 JLG 600HJ...
8ft Fork Extensions (A64553)
8ft Fork...
2022 EZ-GO ELITE...
2017 Freightliner M2 106 TMA Attenuator Truck (A64194)
2017 Freightliner...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
