Quick Disconnects stuck
/ Quick Disconnects stuck #1
RoyJackson
Rest in Peace
Bethel, Vermont
John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
Gents,
My 430's loader (mounted on a Deere 4400) QDs are stuck tight. The slip collars will rotate, but not retract. The tractor is 10 years old, and I'm guessing the previous owner never removed the loader. I never had any need to remove it as it was late in the mowing season when I bought it. Also, I had no level spot to park it last year.
This is the third Deere I've had with a loader and the first one to give me any problems. I always pulled the loaders off for the Spring and Summer unless I had a need for it.
Already sprayed them with both PB Blaster and Fluid Film.
A Deere tech gave me one idea...to tap on the collars as I try to slide them back. That didn't work...
I'm thinking about using a couple flat bladescrew drivers to pry on them and I know that may damage the collars.
So, before I start prying, I thought I'd ask the TBN team for any ideas, experiences or alternatives. Remember, they rotate fairly easily...just won't retract.
/ Quick Disconnects stuck #2
Pushing the collar back towards the tractor won't let them slide? That is puzzling. But am sure you will figure a way. Maybe a vise-grip and something to push agains the grips will get them to move.
Seems a block of wood, like maple or oak, could be used to tap the collar back. Better if a curve in the wood to fit around the male fitting for more contact, but just a tap or two should release the grip.
/ Quick Disconnects stuck #3
G'day Roy check to make sure there is not a small pin that will allow the sleeves to only push down in one spot not common but i have seen it
Jon
/ Quick Disconnects stuck #4
Jon
Not on the Deere QD's. They just slide back over the female end on the tractor side.
No, they won't slide at all. It is a bit puzzling since they rotate.
I'm leery of using vicegrips since a tight enough clamp might deform the collars.
I am prepared to replace the QD's (preferably the females only)...what I don't want is to get one or two (of the four) QD's loose and the other(s) still stuck.
/ Quick Disconnects stuck #6
Be brave :) Take the deere by the horns. ;)
/ Quick Disconnects stuck #7
Roy, I'm sure that you know this but did you release the pressure in the lines by moving the lever to all positions several times with the machine off?
/ Quick Disconnects stuck #8
Roy, sorry to say but your balls are rusty.
Sliding the collar back lets the little ball bearings retract so the male tip can be pulled out. I can only suggest you keep soaking them with the PB Blaster and hopefully they will free up.
/ Quick Disconnects stuck #10
Sliding the collar back lets the little ball bearing retract so the male tip can be pulled out. I can only suggest you keep soaking them with the PB Blaster and hopefully they will free up.
:laughing::laughing::thumbsup:
I believe he is right Roy, I have had this happen with air hose couplers in my detail bay. They are exposed to moisture everyday. I'll bet if they were leaking a little that wouldn't have happened!
/ Quick Disconnects stuck #11
put levers in float position and cut the tractor off .then unplug them.
You bet!
Yeah, I figured they were rusty...kind of surprised they rotate though.
Just looking for ideas so I don't screw it up too badly (but if it does screw up, I'm blaming Compact Tractor Fan anyway...)
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2015 Chrysler 300 Sedan (A61574)
2015 Chrysler 300...
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
