Quick Disconnects stuck
/ Quick Disconnects stuck #1
RoyJackson
Rest in Peace
Bethel, Vermont
John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
Gents,
My 430's loader (mounted on a Deere 4400) QDs are stuck tight. The slip collars will rotate, but not retract. The tractor is 10 years old, and I'm guessing the previous owner never removed the loader. I never had any need to remove it as it was late in the mowing season when I bought it. Also, I had no level spot to park it last year.
This is the third Deere I've had with a loader and the first one to give me any problems. I always pulled the loaders off for the Spring and Summer unless I had a need for it.
Already sprayed them with both PB Blaster and Fluid Film.
A Deere tech gave me one idea...to tap on the collars as I try to slide them back. That didn't work...
I'm thinking about using a couple flat bladescrew drivers to pry on them and I know that may damage the collars.
So, before I start prying, I thought I'd ask the TBN team for any ideas, experiences or alternatives. Remember, they rotate fairly easily...just won't retract.
/ Quick Disconnects stuck #2
Pushing the collar back towards the tractor won't let them slide? That is puzzling. But am sure you will figure a way. Maybe a vise-grip and something to push agains the grips will get them to move.
Seems a block of wood, like maple or oak, could be used to tap the collar back. Better if a curve in the wood to fit around the male fitting for more contact, but just a tap or two should release the grip.
/ Quick Disconnects stuck #3
G'day Roy check to make sure there is not a small pin that will allow the sleeves to only push down in one spot not common but i have seen it
Jon
/ Quick Disconnects stuck #4
Jon
Not on the Deere QD's. They just slide back over the female end on the tractor side.
No, they won't slide at all. It is a bit puzzling since they rotate.
I'm leery of using vicegrips since a tight enough clamp might deform the collars.
I am prepared to replace the QD's (preferably the females only)...what I don't want is to get one or two (of the four) QD's loose and the other(s) still stuck.
/ Quick Disconnects stuck #6
Be brave :) Take the deere by the horns. ;)
/ Quick Disconnects stuck #7
Roy, I'm sure that you know this but did you release the pressure in the lines by moving the lever to all positions several times with the machine off?
/ Quick Disconnects stuck #8
Roy, sorry to say but your balls are rusty.
Sliding the collar back lets the little ball bearings retract so the male tip can be pulled out. I can only suggest you keep soaking them with the PB Blaster and hopefully they will free up.
/ Quick Disconnects stuck #10
Sliding the collar back lets the little ball bearing retract so the male tip can be pulled out. I can only suggest you keep soaking them with the PB Blaster and hopefully they will free up.
:laughing::laughing::thumbsup:
I believe he is right Roy, I have had this happen with air hose couplers in my detail bay. They are exposed to moisture everyday. I'll bet if they were leaking a little that wouldn't have happened!
/ Quick Disconnects stuck #11
put levers in float position and cut the tractor off .then unplug them.
You bet!
Yeah, I figured they were rusty...kind of surprised they rotate though.
Just looking for ideas so I don't screw it up too badly (but if it does screw up, I'm blaming Compact Tractor Fan anyway...)
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A61572)
2025 HT360W Mini...
2025 SF60 60in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
2025 SF60 60in...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A61572)
2025 BS43 44in...
2006 GMC C5500 4X2 BUCKET TRUCK (A59912)
2006 GMC C5500 4X2...
