questions for ck20/25/30 owners
/ questions for ck20/25/30 owners #1
pilemonkey
i am in the process of researching CUT's and i have developed a warm spot spot for kioti. i am looking for something in the 25-30 hp range, FEL, Hydrostatic trans, R4's. this tractor would be used for the following: maintaining a 300' gravel road/driveway, spreading gravel/stone/loam/mulch/chips (maybe 15 yds total per year), lugging/moving things around a 2-3 acre property (firewood, rocks, seasonal furniture, shrubs, oddball scavenged goods, etc.), removing snow initially from a paved +/-50' long driveway and later from the 300' long road/driveway.
obviously the ck20 is not in the 25-30hp range, but i have been rather impressed with the reviews and descriptions of worked performed with it on these forums, so it is still in the running...
on to the questions:
weight - the ck20/25/30 are all significantly heavier than their competitors. the only drawbacks to this that i have thought of so far are that it would tend to foul up a lawn more if used for mowing (i won't be), and possibly issues when trailering (potentially larger, heavier trailer required). is there anything else i should be considering with respect to the additional weight?
hydraulic flow - the 20/25/30 all have higher flow rates than competitors. i would tend to think this would lead to smoother operation when doing more than one function (driving and lowering loader arms, for instance). is this the case?
PTO:Gross HP: the 20/25/30 have somewhat lower PTO:gross HP ratios when compared to competitors. not a huge difference, however (about 73% vs. 76%). is this relevant, or should i be looking at gross hp and pto hp based on implement requirements only?
HP:tractor weight: given the fact that these machines are fairly heavy, the HP:weight ratios are somewhat low. is this an issue?
fyi: "competitors" in this case are JD, NH, and Kubota
thanks in advance for any input.
/ questions for ck20/25/30 owners #2
I looked at the very same brands as you when i was shopping, acutally looked at Kioti last.. I was very impressed with the fit and finish and the price was very good as well. It was easily the best tractor for the money when i was shopping.I ended up with the ck30hst which i purchased in March 05 . I use a 72 in boxblade,84 in landscape rake, both to maintain 800 ft of driveway. I also use a 72 backblade for snow removal and it works very well.I also run the Woods 80x backhoe on mine as well. The weight is beneficial in all areas except finish mowing, which is not a concern of yours as you stated. If you like the hst id recomend either the ck20s or ck30 in the group you mentioned. Both machines are very capable at doing the work you have listed.. Test drive them both. Im sure alot of others will chime in as well... good luck. Matt
/ questions for ck20/25/30 owners #3
Unless mowing is a big part of what you will be using the tractor for, weight is not a problem, but rather an asset. Lighter means smaller truck and trailer. Heavy means more power to the ground, easier loader work, and it'll stay in place when you curl that backhoe bucket. The CK25/30 TLB really is best towed by a 10K trailer to be safe. Though, some do tow with a 7K trailer. This may or may not be important to you.
Big difference in hydraulic flow between the 20 and the 25/30. The extra flow of the Kiotis means faster and smoother operation Will handle more types of hydraulically driven implements too.
The 25/30's also have an independent pto. I don't think that is the case on the 20.
Small PTO hp differences should be taken with a grain of salt. Manufacturers qualify their own numbers somewhat differently, and trannies do vary in efficiency.
HP to weight ratio? I think that's a silly metric, unless using the PTO at full power on steep slopes. HST will have a little less hp than the Gears at the PTO too.
I have the CK25 on similar size lot as yours, with similar tasks. It's huge, but not so big that it doesn't fit. If you have tight spaces, the CK20 might work better for you. I started out looking at the 20. The deciding factors for me were the extra weight and hydraulic pump capacity (bigger, faster backhoe). I was thinking HST originally, but after driving the shuttle shift on the CK25, I decided that a CK25 gear for just slightly more money than a CK20 HST was the way to go for me.
Good luck in your shopping.
/ questions for ck20/25/30 owners #4
I just went through the selection process like you. While i gave some thought to JD and NH, the battle was between the two orange k's. kubota was a great tractor but when i saw that Kioti and looked over the heavy axles and actually grabbed the solid fenders and grab handles and raised the hood........well that was the tractor for me.
I bought a new CK20(s) HST 22 h.p. with FEL, BH, and snow blower. I have to say I only have 18 hours on it and have done nothing other than snow removal but have i ever moved the snow. Those Wind packed drifts from lake Michigan have crashed the beach homes making them inaccesssible until Until my CK got a hold of that white stuff. I'm tallking snow drifts 10' - 12'
high. I have been particularly impressed with the nimble turning ability of my CK20.It can literally turn around in it's tracks. I have plenty of power to ram into banks of hardened snow left by pick up trucks trying to push some of their old banks back to make room for new snow. I either front bucket that concentrated packed stuff bucket by bucket to remove it or I cut it away from the drift and break it up so I can back my blower through the stuff and give it a one way ticket out of the way.
As for the pto horsepower, I'm thinking Kioti is very conservative with that figure and I don't understand why the industry varies so widely in perceiving this number. I have the HST and still think it's got plenty of power. The FEL hydraulics at 2000 rpm with a full bucket of compacted snow is plenty fast. I am aware compacted snow is lighter than dirt but this stuff is still heavy and my bucket is heaped.
I will trailer the 20 on a 16' car hauler with 7000# capacity. The trailer worked fine on it's 10 mile maiden voyage. Not lot's of time in the saddle yet but I think i got the right tractor for my needs. Check em all and then grab the Kioti right by the fender and try one out.
rimshot (heavy is beautiful if you're a tractor)
/ questions for ck20/25/30 owners #5
The CK30 that I bought last year is my 4th tractor (I am no tractor expert by any means). The first was a Ford, the next 2 were Kubota's. All 3 served me well. I got the Kioti becuase it was several thousand dollars less than an equivelent New Holland or Kubota. But I have got to tell ya, this CK30 is an animal !!!! I use my tractors! (not abuse) At 148 hrs. it has moved 1000# safes, (I am a locksmith), moved yard and yards of dirt, stone creat, built 2 drive ways and dealt with 26" of snow (in Feb alone) and sub zero temps here in Michigan. I could go on and on. Sure I have had the typical small warrenty issues like a burnt out preheat indicator bulb etc. This is one wild workhorse of a compact tractor. My neighbor just got a new Cub 23 hp lawn tractor with all the toys and spent $7200.00. I just look over (and down :) ) at him and smile!!!
So i say go 30hp and order it with industrial tires and save up for a set of turfs!!! JMHO
thanks to all of you for the quick (and informative) replies. this certainly helps to pare away some of the decisions. it sounds as though most of you are using your tractors for similar tasks as what i have in mind. so, next round of questions:
20 vs. 25/30: i have not test driven anything yet - hopefully this spring/summer. i am thinking that if the 20 seems like it will do what i want, it may be handy in that it occupies a smaller footprint. if not, i'll be looking at the 25/30. i have read that the 25 hst tends to be underpowered somewhat. thoughts?
gittyup: you stated that you have a ck25 gear. are there any tasks that have made you wish you had the 30 hp? also, i am a little unclear (uneducated) on the independent vs. non independent PTO. what is the difference and how/when would i know or care about the difference?
q/a or not: at some point, i think it would be nice to have a q/a system (factory or otherwise). i am also thinking that one of the first things i'll do is install a toothbar and receiver system on the bucket. the receiver system will allow me to attach a boom pole, forks, etc. in your opinion, am i wise to see how things go, or just bite the bullet initially and get a q/a setup? also, i think there are different types of q/a systems. i am leaning toward a skid steer type. does this make sense?
block heater: given that i plan to clear snow with this, what are your thoughts on a block heater? local dealer says the glow plugs work fine with virtually all of his customers and that a heater could be wasted money. thoughts?
thanks again for your input. getting real time feedback from you really gives me a level of confidence in some of these decisions.
/ questions for ck20/25/30 owners #7
Regarding the CK25 HST being under powered. I can't really say for sure because I haven't used one. Just make sure that such statements are based on experience rather than perception or conjecture. I'd be surprised if Kioti would sell it if it were really true.
So, far I haven't been wanting for more HP. I run a Bushhog brand CS-100P chipper/shredder off the PTO. It takes 5" hard, dry logs with ease. You do have to hold back on them a bit to keep the motor from bogging down as the chipper is a very fast monster. I've also run a 12" post hole digger. Cuts right through big roots, and big power line cables (miss utility was wrong), and also dispells big rocks. Not so much as a hiccup while doing it. I don't brush hog with it. That and tilling would probably put the biggest loads on the PTO.
Independent PTO differences come into play on the gear models only (I think). The CK25/30 has a 2 stage clutch. Push part way disengages the tranny only and leaves the PTO running. Push all the way and everything is disengaged. On the CK20, it's all or nothing. This will make a difference when snow blowing or mowing, and while shifting gears. Do a search on the Kioti forum. It has been discussed recently.
Difinitely go QA. I wish I had. I have a toothbar and it works great for digging into hard piles. But it isn't so good backdragging. It does go on and off in about a minute though. I would get one.
If the dealer is suggesting you don't need a block heater, then you probably don't.
On your backhoe, make sure the dealer puts on rear remotes using big hoses (1/2"). That way you have the remotes for other purposes and the big hoses will improve implement speed.
/ questions for ck20/25/30 owners #8
I don't need a heater, but I have a lower radiator hose heater. My CK30HST will start easily without the heater (lowest I've had is about +10F) but after heating it for an hour or two it starts and idles and sounds like it does in the summer, that must be better for the engine...
Mike
/ questions for ck20/25/30 owners #9
Test drive both the 20 and either the 25 or 30 to see which fits you best. As far as 25 or 30 I don't think there's that much difference with 5 ponies with what 95% of owners use 'em for. I guess if you at the edge of the PTO ratings for a particular implement the few extra ponies might encourage you to spend the extra bucks. If the area you plan to operate in has limitations the 20 might fit the bill. Just don't undersell yourself on your purchase, plan for any/all intended future uses.
QA? If you are thinking about it now, get it. You'll kick yourself later for not having it. I have it on my ck30 and it is by FAR the most time saving gizmo on the tractor, litterally worth it's weight in gold, OK maybe silver.
On the block heater, I guess it depends on where you live and what the average temperatures are going to be where your store/operate your machine. Your dealer is probably part right, meaning that yes your tractor will start just fine with the glow plugs in winter temps, but will it easily? Also, if the block & oil is warm it is easier on the engine during start up, oil moves through the system easier, faster. To me that is cheap insurance for longevity in the engine's lifespan. Mine has always started with or without the heater, but sure doesn't sound great at -10* w/o though. My selling dealer automatically adds block heaters to every new Kioti he sells, for like the last 22 years, he must know a thing or two I'd think........
Good luck in your tractor hunt.
WK
what would you recommend as far a q/a systems? i am leaning toward something that would utilize a skid steer mount. does anyone have this and if so, what are its strengths and weaknesses?
gittyup, i am not planning on getting a backhoe right now, but i am glad you brought up having rear remotes installed. this is something else i have been tossing around. i don't know that i'd have any use right away for them, but i'm thinking that cylinder actuated angle adjustments on a rake/blade would be nice at some point. it this something that i can do myself later on, or no? what about adding one up front on the FEL for a grapple or something? is this something i should have a dealer do, or is it something that someone with a reasonable mechanical aptitude can handle?
thanks again for everyone's input.
/ questions for ck20/25/30 owners #12
Tim M said:
ATI, Horst and a few others make an add on for the Kioti 130 loader.
ATI Corporation - Tach-All(tm) Quick Attach
Millonzi
I had the Horst QA adapter on my CK20/KL120. Worked great. Very heavy duty (and heavy). It was actually heavier duty and more weight than the QA adatper that comes standard on the KL401 loader. My point is the Horst may be overkill but is certainly a quality piece of equipment. By the way, I am pretty sure that the KL120 and KL130 have exactly the same pin mount so anything that fits one will fit the other.
/ questions for ck20/25/30 owners #13
I'm in SE Michigan, and I've been going through this same debate for, well, a couple of years now. :p I've finally had it with moving snow off a 350 foot driveway with a 1976 21" Toro snowblower, and my daughter is off at college so I'm selling (hopefully) our big horse trailer that's just sitting idle now to help pay for a tractor finally.
My intended uses:
(yearly)
-5.5 acres
-snow plowing 300+ feet of asphalt drive
-moving trailers to/from my barn on the back of the property, with a fairly steep hill to get to it (can't get my 4x4 truck with big mud tires down there for a good portion of the winter)
-clearing dead trees & brush around the perimeter
-3pt sprayer for 10-12 fruit trees
-Possibly, if I end up keeping the horses, that will require a 3pt post hole digger for a bunch of fencing, and moving small 4-5' round bales
- dragging a large roller/aerator to smooth out the lawn
(one time projects in the coming years)
-moving some large downed trees to cut up for firewood (chunks at a time, a borrowed 40hp 4x4 JD wouldn't budge the trees)
-I need to regrade around my barn and put in a couple hundred feet of french drains
-Possibly run a 3pt trencher for the drains and running power 100+ feet to the barn (or possibly add a backhoe to do this and the drains)
-help rebuild some retaining walls & move a bunch of concrete chunks prior owners used to _try_ to build said walls.
I originally had myself talked into thinking the ck30 HST was the way to go. Now I'm wondering perhaps the ck20 HST would be plenty of tractor, eaiser to do the close in grading work around the barn that needs done, and should be way more than enough for the yearly work moving snow etc. I don't plan on doing any mowing.
I've tried a ck30 hydro at a dealear that's since gone out of business. It worked well. But i'm also considering whether the hydro is really worth it, I've run/owned other large (gear) farm tractors over the years, and I run a 40 HP JD tractor/loader with a powr-reverser or whatever they call it quite often, doesn't seem to really be any problem. I can see how the hydro might be nice for the really 'surgical precision' grading work, but not sure that's worth the extra cost over the long haul.
I was also going with Ag tires because I need to be able to get it up and down the grassy hill from the barn through whatever snow there is. I've never had R4s on a tractor before, but they don't look like they'd do too great in the deep snow...
Comments appreciated.. :)
/ questions for ck20/25/30 owners #14
I don't see anything on your list that would give a CK20 any problem. You mention small bales and that would be the only question mark but if the bales don't weigh more than 600lbs or so I don't think you'd have trouble. The CK30 loader lift capacity is only 8% more than the CK20 loader anyway so if the CK20 has difficulty it is likely the 30 would also be marginal.
I cannot comment on the Ag vs R4 tire thing except that I haven't had any trouble with traction using R4s on both a CK20 and DK40se. In snow I'd probably use chains or at least plan on that as an option if traction was a problem.
/ questions for ck20/25/30 owners #15
CurtC,
If you get a lot of snow where you are in SE Michigan, which I am assuming you do, you really should consider a rear mount snowblower. And if you do opt for a snowblower you are really better off with a HST. Search for threads by DMace on his CK20. I think a similar set-up would be just what you want.
I have R4s on my CK25 and have never had any problem with snow. I just use my 64" snowblower to cut a path to where ever I want to go.;)
BTW, if you only have one job that requires trenching you would be far better off to rent a peice of equipment to do that job and spend the savings on other attachments.
/ questions for ck20/25/30 owners #16
My personal choice would be the bigger tractor, just for the added weight and greater hydraulic capabilities.
I have gear. It works good for me. But, I like HST a lot for mowing and when there is a lot of back and forth. Hard to beat the fine control it gives you. If you go HST get the CK30, or the CK20S. However, it appears the 20S might have some cold weather starting issues. Though I don't think there is enough data one way or the other on this quite yet. If you like the gear, I don't see much difference between the 25 and the 30, unless your tasks require a lot of PTO power.
I have R4's. I wish I had Ags. Anybody want to trade wheels? The R4's load up easily in mud. Then they are useless. Can't speak to performance in the snow. But, I would think R4's would stay on top better given their much wider footprint.
/ questions for ck20/25/30 owners #17
I am also in SE Michigan and have had a CK30HST for a couple of years now. Have had no problems with the back blade clearing my 700' of driveway and making walking trails to get to the animals. The 30 has been a great size for me, have never lusted after anything larger or though I should have gone smaller. As someone else mentioned, if you are going to do alot of snow work the HST is a great thing to have. My drive winds a bit and the HST sure does make it easier in reverse. Good luck ! I honestly don't think you can go wrong with the CK30.
2018 International WorkStar 7500 Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A59230)
2018 International...
LEEBOY 8510B ASPHALT PAVER (A60429)
LEEBOY 8510B...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
2008 KENWORTH T300 FLATBED FUEL TRANSPORT TRUCK (A58214)
2008 KENWORTH T300...
2014 Freightliner 105' Bucket Truck (A61306)
2014 Freightliner...
