Quality battery charger/maintainer?
/ Quality battery charger/maintainer? #2
I'm partial to CTek, I have it and it's great. Internal parts are 1st class and it's also standard for the likes of Rolls Royce/Bentley Aston Martin Porsche Ferrari etc.
It will save you batteries give them a much longer life. A bit pricier than others, but the built quality warrants it.
/ Quality battery charger/maintainer? #3
How about solar powered charger/maintainers? At Casa Paratus Norte there is no electricity except if I bring it in with a generator. So Solar for keeping the battery on the 3930 sounds promising, assuming there is some decent quality out there..
Thanks, tired of wasting money on "disposable" units that aren't reliable or accurate. Schumacher XCS15W just overheated a battery in one of my trucks. Claimed it was in maintain mode, fluid bubbling from vents, case warm to touch. Unit was putting out 16 volts, was working near truck smelled a battery odor, glad I checked it out.
Thanks,
Q
/ Quality battery charger/maintainer? #5
I have a "Battery Tender Plus" that has been working for 5 years straight without issues. Think I paid $70 for it, I'm sure there is better..
/ Quality battery charger/maintainer? #6
Try these-----https://no.co/products
/ Quality battery charger/maintainer? #8
I bought mine from Napa 20 years ago. I have no idea if they are still good. Electronics and China have away of ruining a good brand.
/ Quality battery charger/maintainer? #9
++1 on CTEK..
/ Quality battery charger/maintainer? #11
/ Quality battery charger/maintainer? #12
Thanks,
Q
I don't buy Schumacher, Century, or Harbor Freight battery chargers.
I have already had my once in a lifetime MAJOR fire.
For unattended electrical equipment, I buy the highest quality that I can find, and Schumacher, Century, or HF ain't it!
/ Quality battery charger/maintainer? #13
What do you use ?
/ Quality battery charger/maintainer? #14
What do you use ?
I have a mix of Battery Tenders, and Battery Tender Jr's, but I don't like them. Several have failed, though none have smoked. They are somewhat old technology.
I think the best bang for the buck is the Battery Minder 1500, I have several Battery minders.
I am going to try the NOCO Genius G1100 next.
I leave all (17) of my batteries unattended for up to 6 months.
/ Quality battery charger/maintainer? #15
I got a 150 amp alternator in my truck,,,
WHY does my truck not charge the trailer battery when I am driving?? :confused2:
/ Quality battery charger/maintainer? #16
I have a mix of Battery Tenders, and Battery Tender Jr's, but I don't like them. Several have failed, though none have smoked. They are old technology.
Look very closely at this, and the NOCO, I think they are the same, I just bought one and the manual and packaging are the same..And its much cheaper.
https://www.homedepot.com/p/Smarter...olt-12-Volt-Battery-Charger-IC-1000/303114813
/ Quality battery charger/maintainer? #17
Likely because you don't have the 7 way plug wired right or the fuse has blown. With truck running,looking into vehicle side of plug with indexing key at 12 0-clock,#4 terminal at 1 o-clock should read more than 12.9 volts. Why that fuse commonly blow's is a subject all of it's own and deserve's a dedicated thread.
Thanks everyone, have been thinking about my requirements. I like the features of my POSchumacher, 15 amp/3 amp charge setings, Std, AGM and Gell battery settings. I have a Deltran 1.5 amp tender, its older and works well but it's really just a tender, charge from low/flat to charged takes many hours. I'd like the same features as my POShumacher in a higher quality package, 15 and 3 amp charge and battery type choices with auto switch over to maintain once fully charged.
Thanks,
Q
/ Quality battery charger/maintainer? #19
Thanks,
Q
Deltran sell's chargers with those features but how often do you need to charge from discharged to maintaine while not being in attendance? On rare occasions when dealing with low/no charged battery, I put my 10/5/2 charger on until 60% to 80% then switch to one of my 1.5 Deltrans. When connecting 10/5/2,if I don't plan being around I plug into timer to protect from overcharge. One of my 1.5 Deltrans is 14 years old,the others are over 10. All of them top off then hold 12.7 volts,some times for months on boat.
True, I have way to many vehicles, hard to start/drive all regularly, like the convenience of the 15/3 amp charge auto switch to maintenance mode. I have a 1960s Craftsman wheel model for charging when I around
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2016 John Deere 1200H Bunker Rake (A66734)
2016 John Deere...
1999 INTERNATIONAL (INOPERABLE) 4900 (A67714)
1999 INTERNATIONAL...
2007 Freightliner M2 112 Tri-Axle Dump Truck (A66736)
2007 Freightliner...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A64280)
(INOP)1989 NISSAN...
2018 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A69167)
2018 FREIGHTLINER...
