Put in a new Battery, got nothin' - I am not dumb, but maybe I'm not bright?
   / Put in a new Battery, got nothin' - I am not dumb, but maybe I'm not bright? #22
I will not charge you with interference, not a terminal offense. Because starting was getting slower and its been in there for 4 years. Did not want to hit winter with a questionable battery. I live in Buffalo and use my LS to get the drive clear. Also gives me an excuse to drive the tractor in the winter.
ArArr: 'charge you' & 'terminal offense.'
Wish I was that funny!
   / Put in a new Battery, got nothin' - I am not dumb, but maybe I'm not bright? #23
All you have to do is find a known good 12v battery. Yours, friend, neighbor, etc.
Swap it in.
Another choice which I have done is if you have a Walmart with Auto center or any car parts store they'll test it.
Everyone should have a multimeter and know how to use it. A good charged battery should measure about 12.6 to 12.7 VDC. Verify that by checking your car or truck battery.
I'm really just repeating advice given here already.
As a retired 43 yr. electronic technician I can tell you most every problem is simple. Don't go on a wild goose chase.
Just yesterday I'm mowing with my JD455...running great, shut it off, then completely dead. I had a screwdriver with me.
Put it on + terminal, whacked it...nothing.
Tried -- terminal which swiveled a bit. Started/ran fine.
Three minute "fix". (I should clean terminal).
   / Put in a new Battery, got nothin' - I am not dumb, but maybe I'm not bright? #24
Eden tractor is an LS dealer right on Rt 62
   / Put in a new Battery, got nothin' - I am not dumb, but maybe I'm not bright? #25
You say the ground is attached to the battery box?
Move it to the engine block or better yet is one of the starter mounting bolts
   / Put in a new Battery, got nothin' - I am not dumb, but maybe I'm not bright? #26
How about a pic with those caps pulled back??
Your problem must be something real simple right there at the battery. Hard to believe you have a new battery that's so dead it won't even light up a dash light or make something click -- but it's possible.
Someone asked if you put the battery cable ends OVER the plastic caps that come on a new battery post. Did you check for that? Is the red or black cap still on one or both of the posts?
   / Put in a new Battery, got nothin' - I am not dumb, but maybe I'm not bright? #27
I have a NH, and to start tractor, must be in neutral and you have to push key in while turning. It happened to me many times until I figured it out. Sometimes I was just pushing in key as coincidence, so it took a while. i also thought of plastic caps on battery...
   / Put in a new Battery, got nothin' - I am not dumb, but maybe I'm not bright? #28
He said nothing lights up though. Acts like there's NO battery in the tractor. Has to be something really simple right at the battery.
   / Put in a new Battery, got nothin' - I am not dumb, but maybe I'm not bright? #29
Damn speed reading woes...
   / Put in a new Battery, got nothin' - I am not dumb, but maybe I'm not bright? #30
Swap it in.
Tried -- terminal which swiveled a bit. Started/ran fine.View attachment 4375375
I try to check a new battery with a meter before I even leave the store because I’ve had new bad ones before. Even a test light could be useful here. A meter is better but a test light could let you know if it’s totally dead or not.
2016 Dodge Charger Sedan (A55853)
2016 Dodge Charger...
UNUSED RAYTREE RABC44 - 44" BRUSH CUTTER (A57193)
UNUSED RAYTREE...
DIRT DOG APP48.3 (3) SHANK 48" SPRING TOOTH HARROW (A57192)
DIRT DOG APP48.3...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A55852)
2014 Peterbilt 384...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
JOHN DEERE 35D EXCAVATOR (A52707)
JOHN DEERE 35D...
