tradosaurus
Super Member
- Joined
- May 8, 2017
- Messages
- 6,147
- Location
- Texarkana, TX
- Tractor
- Kubota MX5400 HST, heavy duty bucket, 3rd function, R1 tires (rears filled), 2 remotes
I am looking at buying a PTO generator but all the information on youtube and post is confusing.
I need someone to explain the sizing, the operation, and hookup without using too many acronymns and as if they are teaching a 6th grade class.
I have a Kubota L3301 tractor with 28 PTO hp.
I'm thinking about using a 50 amp power outlet box and wiring that to a 50 amp breaker to my main feed panel so that if power ever goes out I flip the main power off, plug in the generator and then feed the house. RVGUARD 5 Amp 125/25 Volt RV/EV Power Outlet Box, Enclosed Lockable Weatherproof Outdoor Electrical NEMA 14-5 R Receptacle Panel, ETL Listed - - Amazon.com
I've seen generators with AVR and without and don't understand the advantages.
It looks like a 15-16 kW PTO generator would work.
Once you hook the generator to your house and tractor do you just max out your tractor RPM, flip the generator to on, and start using powering anything you need in the house unless the breaker trips?
