3-Point Hitch PT attachment use on my 3PH
   / PT attachment use on my 3PH #11
When I acquired my used PT2445, I picked up a funny looking rear PT plate scenario that connects on the back (when backhoe is removed). I....
I think that was the optional rear hitch they sold on some of the larger models. It was discontinued, if I'm not mistaken.
   / PT attachment use on my 3PH #12
What kind of tractor are you thinking about using the PT attachments on? Make sure you have enough GPM and PSI to run them.
   / PT attachment use on my 3PH #13
I'm the guy he will be swapping with.
His tractor is one of the other green ones. His system runs 9.3GPM@2500psi, so the trencher & PHD should be safe as long as he doesn't quite run wide open. They'd probably be fine even then.
2020 CATERPILLAR 289D3 SKID STEER (A60429)
2020 CATERPILLAR...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56438)
Neckover GL24-2-7K...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 Toyota Camry Sedan (A59231)
2008 Toyota Camry...
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
