3-Point Hitch PT attachment use on my 3PH
   / PT attachment use on my 3PH #11
When I acquired my used PT2445, I picked up a funny looking rear PT plate scenario that connects on the back (when backhoe is removed). I....
I think that was the optional rear hitch they sold on some of the larger models. It was discontinued, if I'm not mistaken.
   / PT attachment use on my 3PH #12
What kind of tractor are you thinking about using the PT attachments on? Make sure you have enough GPM and PSI to run them.
   / PT attachment use on my 3PH #13
I'm the guy he will be swapping with.
His tractor is one of the other green ones. His system runs 9.3GPM@2500psi, so the trencher & PHD should be safe as long as he doesn't quite run wide open. They'd probably be fine even then.
2013 FORD F250 (A60460)
2013 FORD F250...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
2020 CATERPILLAR 289D3 SKID STEER (A60429)
2020 CATERPILLAR...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
