Preventing tractor back flip
/ Preventing tractor back flip #41
See the simplified diagram below.
If "A" moves forward, "E" will rise.
Bruce
On a real tractor 'B' 'D' and 'A' are not fixed in one plane.
D is fixed to B, but A rotates independently around B. So A could go forward or backward without B moving.
I think something is wrong with your idea but I don't quite know what. Nevertheless I do agree it could flip... as I said in my previous post.
/ Preventing tractor back flip #42
could it help to look at some conditions "at the limit"?
1) The drawbar is a lever arm: suppose there were sufficient weight pulling straight down? I suspect the tractor would turn about the rear axle.
2) The rears normally rotate and the axle-housing is stationary: suppose you had enough torque, everything was strong enough not to break, and the rears were immoveable? I suspect the axle housing (and thus, the tractor) would rotate.
So, in the limit, it seems like there can be situations where rotation is initiated ...and, if there is sufficient momentum and nothing to stop the rotation, over she'd go, right?
I can imagine that trying to go up a sufficiently steep incline, with enough torque, would cause the tractor to "counter-rotate".
just my thoughts
[of course, one should still always pull forwards, from the drawbar and not from some higher fixture ...if you tried to pull a relatively immoveable object backwards from a high FEL attachment point, the rears would come up, no? That is the tractor would count-rotate around the front axle ...that is, until the bucket smacked into the ground]
/ Preventing tractor back flip #43
just my thoughts
I have heard of (not seen) of rear tires frozen to the ground after rain and freezing temps causing the tractor to instantly flip as soon as the clutch was engaged, and going up a steep incline, every tractor becomes light in the front, so the likleyhood of a flip becomes greater.
James K0UA
/ Preventing tractor back flip #44
While the theories are bouncing around....It may be worth mentioning that there have been hundreds, if not thousands of cases where tractors HAVE flipped backwards when pulling from a low mounted draw bar. The fact that it DOES happen with some minor degree of regularity SHOULD influence the possible v impossible voting.
/ Preventing tractor back flip #45
The higher the hitch point the easier it will be for front wheels to raise off the ground therefore being easier to FLIP. If a tractor has enough HP and traction it will flip no matter how low the load is attached. Just look a the puller tractors that are required to have wheely bars
/ Preventing tractor back flip #46
As long as the contact point of the tires and ground are lower than the tow point leverage exists that lifts the front. The closer thay are to gether the less likley it is to happen.
/ Preventing tractor back flip #47
Some of you keep mentioning a relationship of the axle height to the drawbar. Not important.
You've got force #1, the contact patch of the rear tires on the ground trying to push forward. And you've got force #2, the attachment at the drawbar trying to pull backwards. Since those two forces are not colinear, they result in a torque. Since force #2 is above force #1, that torque acts to rotate the tractor up and over backwards.
The only things that will prevent a backflip are the lack of either enough power or enough traction to complete the job.
xtn
/ Preventing tractor back flip #48
Look at this video. At the start you can clearly see the hitch is well below the axle. Later in the video the front wheels are well off the ground. If the same thing happened at higher speed with bouncing wheels, erratic traction, unpredictable backlash, and other unexpected forces going every which way, then its easy to imagine it could flip all the way.
To me, it somewhat defies logic but see for yourself...
‪John Deere 2 Cylinder Pulling‬‏ - YouTube
The force applied to the ground has no relationship to the axle or where the draw bar is relative to the axle. It is a straight force applied parallel to the ground regardless of wheel size or axle location. The draw bar is a certain distance above the point of force and an opposite force is applied. The only thing keeping these forces in check is the cantilevered weight in front of the point of force (i.e. the front of the tractor).
The draw bar is located below the axle, not because of some magical property that would stop the tractor from flipping, it is just the lowest point and the lower the point, the less rotational force can be applied to the tractor.
The video has all the supporting evidence.
/ Preventing tractor back flip #49
/ Preventing tractor back flip #50
Well, I tried that once, and the first thing that happened when the weight came off the rear wheels was all kinds of parts in the front drive broke or bent as the situation required (it was quite a loud noise). I did the labor and the 12 pounds of parts from Mitsubishi cost a cool $2,000. (Ring, pinion, sun gear, two bearings, two bevel pinions, all broken, and both axle shafts bent {I straightened these} and assorted seals). I don't try that anymore.
/ Preventing tractor back flip #51
Bruce
Actually, in the configuration that the PO described, "A" would have to move backwards.
The tractor would flip over with the load attached under the axle only if the tractor is dragged backwards, and chain winds up like a spool of thread around the axle. It might happen...
JayC
/ Preventing tractor back flip #52
It will still flip over :(
It will just be more of a sling-shot flipover :( :(
You're right, initially the front wheels will be driven into the ground, but then given enough rear wheel traction, something has to give. That something is the front end switching from being jammed into the ground to being sling shot (slung shot?) upward, & over.
Nope;
Not even on a cogged track.
Attend a pull some time.
Watch the front end rise, watch the draw bar lower, see the equilibrium.
You will NEVER see a tractor flip STRAIGHT over backwards at a pull.
If one somehow gets off line - that is different and it will be a weird nasty diagonal sort of thing.
/ Preventing tractor back flip #53
It's all about angular vectors. Sorta like a rotary airline engine.:)
/ Preventing tractor back flip #54
I have a friend who has flown about as many different types of aircraft that you can imagine. He used to ferry planes for a living. He told me that one of the most wicked planes to fly was the P51. He said that the engine had so much torque and the prop was so large and had so much "bite" that you literally could roll the plane over while sitting on the ground if you applied the throttle too fast.
He said that you had to roll the throttle in slowly as you took off until the right wing developed enough lift to counteract the torque of the prop.
I can see the same thing happening in a tractor given enough torque and traction.
/ Preventing tractor back flip #55
This.
xtn
/ Preventing tractor back flip #56
They wrote that the torgue was horrible on the Jug fighter aircraft, also know as P-47....It also had a huge prop like the p-51. I am amazed when I see either one at a airshow...Plus the loud-ness of the engines.No wonder our veterans were hard of hearing. But back to torgueing tractors..
/ Preventing tractor back flip #57
About the only way I can see a non-flip over is if the
towing point is well ahead of the rear axle. I don't
think you'd get enough rotational force to flip the tractor
before the rear wheels broke traction. Of course, if the
rears didn't break traction, the tractor might have enough
force to still flip.:(
Bill
/ Preventing tractor back flip #58
Nope;
I'm of the opinion that the reason you rarely (if ever) see a tractor flip straight over backwards at a tractor pull, it's because the tires are almost almost always spinning, and they usually add enough weight forward of the rear axle to keep the front end about 3 ft off the ground (for best weight transfer).
Now, I also have the opinion that if you have something hooked to the rear of the tractor and it offers enough resistance, be it attached above the axle or below the axle, and with enough torque from the engine, and if one or both of the rear tires suddenly finds traction and stops spinning, that it can and WILL almost certainly flip over backwards. That may be an uncommon sequence of events, but that's why they call them accidents.
I think there are enough deceased tractor operators that would almost certainly bear witness to that, if they could only speak now. That's all I'll say about it.
/ Preventing tractor back flip #59
Does hooking up a chain short or long make a difference? Short being as close to the object as possible.
/ Preventing tractor back flip #60
Yes, but is there anything more memorable than listening to a P51 idleing in its unique way on the runway, and when the pilot puts the spurs to it, that heart vibrating, earthshaking sound, and to watch it lift off and climb so fast and so vertical?. It is something I will never forget. It is no jet, but just about the culmination of piston powered aircraft if you ask me.
James K0UA
CONVEYOR BELT (A67714)
HONDA Plate Compactor (A64557)
HONDA Plate...
CAT 621B Transmission (A68134)
CAT 621B...
Turf Tiger Velocity Plus (A64557)
Turf Tiger...
2007 Toyota Rav4 SUV (A66738)
2007 Toyota Rav4...
2021 Cub Cadet Ultima ZT1 50in. Zero Turn Mower (A64557)
2021 Cub Cadet...
