Preventing tractor back flip
/ Preventing tractor back flip #341
All,
I just joined TBN and part of the registration is posting for the first time. This string looked particularly interesting, anyway - what is the moral of the story? What should I know to not kill myself trying to move an object too heavy for my JD 1050? In a previous life, I had bad experiences drawing vectors for a demanding (and obnoxious) instructor - when someone recommends getting out the paper & pencil, I generally look for the door. Is it correct to say that pulling from the front while in reverse is safest?
Jim
On a flat surface, take a piece of plywood, lay it with one edge just a little behind the rear tire ground contacts and lift the other edge til the plywood touches both tires and the drawbar end. Measure the angle wrt the surface. This is the tip angle at which the drive force causing a tip and the load force acting on the end of the fixed drawbar are both acting at ground level. This cancels the tip force. A slow tip will not go further. A fast tip will "coast" higher but at the same time be resisted by load force because the drawbar end will be below ground. A fast tip has a cascading effect because it accelerates the tractor CenterOfMass upward. This acceleration causes greater downforce on the rears, thereby increasing traction. Without wheelslip or engine bog the force geometry says the tip will speed up as you tip - a chain reaction. If your measured angle is 30ー you are pretty darn safe because a tractor takes about 60ー from level before it will fall over backward - the tip has to be so fast it will coast on up an additional 30ー. If its 40ー or more I would worry some and try to lengthen or lower the drawbar until it is below 40ー.
larry
/ Preventing tractor back flip #342
I admit I'm a guy who is slow to go looking at previous threads on a current subject, what with close to two and a half million posts in the can, but I'm not a great reader (lysdexia). But this thread is less than two weeks old, and I took the two weeks to read most of it in something approaching real time. I have had my say on what can happen pulling backwards from a bucket hook. That cost me $2,000 in parts and a many hours of work once. I still do it, but not so aggressively.
While I never gave the back flip much thought, it seemed that I believed that if your pulling point was lower than the rear axle, it would not happen. This thread made me rethink the problem and that rethinking is what changed my mind. I can now see how it could happen. I may have been right before and am now wrong. But one thing is for sure, I'll probably err on the side of caution.
/ Preventing tractor back flip #343
I think, all situations are different, but being "aware and cautious" is a prudent move. Some other things are just "obviously dumb".
/ Preventing tractor back flip #345
When I pull skiffs uphill from the fel it will lift one or both rear wheels off the ground even with the backhoe on. I usually grab a piece of piling in the backhoe for a little more weight but you still have to watch it.
Rick
/ Preventing tractor back flip #348
Wow. Has there ever been a faster growing thread on TBN? From 0 to 348 posts in less than 2 weeks.
/ Preventing tractor back flip #349
There is at least one more thing, which should be considered.
Repeated operations could differ, one from the other. I'm thinking about skidding logs, for instance. Just because one log was skidded without incident, doesn't mean the next log will skid the same. It could roll differently, while going around a tree, and get snagged on the tree. Or the last log may have exposed a rock, which will snag the next. You get the picture. "Every pull, is a new adventure".
/ Preventing tractor back flip #350
There's been a lot more armchair engineering then fact on this thread, but your drawbar provides the hook up that is least likely to result in a rear rollover...reducing the possibility to negligible on a level surface. Slopes...well, a different issue altogether (moves your tractor's center of gravity)...same with trying to jerk a pull to get it moving.
Use some common sense and have a bit of respect for your equipment.
/ Preventing tractor back flip #351
That's why I bowed out earlier. Too many variables in real life situations to conclusively say that it 'cannot happen'.
/ Preventing tractor back flip #353
We chased that bubble like our lives depended on it. Wanna try it? :)
I pretty much destroyed a front drive, but I was both lifting and pulling backwards on what turned out to be a nearly immovable load to the point where only the front wheels had any traction. It was a learning experience. $2000 and a lot of hours of OJT. I can tell you it was a loud noise when all those parts broke at once. Just look at the difference in the sizes of your front and rear components and act accordingly.
As long as the pull is straight, using that bucket like a fishing rod on a halibut is a technique I use often.
Sorry to hear about your problem. Not surprising that your front end got busted up. If the front wheels would have broken traction and spun, you'd been OK. First thing I found out about 4WD on tractors is that you never, ever use the tractor and FEL on a high-traction surface (like concrete) to push into going forward or pull backward on a heavy, immovable load. Sure, it's a judgement call regarding the traction capability of the surface, but if your judgement is off, you pay the price.
/ Preventing tractor back flip #354
Yeah, I keep bringing it up so others won't have to go through what I did. It was about six years ago, but those extended times when the tractor is down are memorable. The previous owner of that tractor had busted the ring and pinion when he drove it down a steep bank and broke the front drive trying to back out. The dealer shop where he bought the tractor (now out of business) put in the wrong ring gear which led to my first front drive failure. I fixed that and then went and busted it myself. I don't want to tear down another front drive, where twelve pounds of steel can cost $2,000.
/ Preventing tractor back flip #355
Just bought a JD 1050 w/ FEL and 4WD. Does anyone know whether I can fill the front axle fluid reservoir from either fluid port? I can only open one fluid cap and if that one does the job, I'm happy.
Jim
/ Preventing tractor back flip #356
Jim
Try posting a new thread in the John Deere section here John Deere Owning/Operating - TractorByNet.com
instead of asking this question in this thread, which is totally un-related.
You will probabally get pleanty of responses and help there:thumbsup:
Generator (A64553)
Generator (A64553)
PORTA POTTY (A68842)
2024 CRUISER RV SHADOW CRUISER (A67714)
2024 CRUISER RV...
CM TRAILER  10 FOOT ENCLOSED TRAILER (A67714)
CM TRAILER 10...
2003 Honda Pilot AWD SUV (A66738)
2003 Honda Pilot...
2013 Dodge Avenger Passenger Car, VIN # 1C3CDZCB4DN759234 (A66738)
2013 Dodge Avenger...
