careyo63
Elite Member
- Joined
- Jan 6, 2012
- Messages
- 2,835
- Tractor
- 77 Yanmar YM2000 63 Ford 2000
Sent you a PM. On a tablet so make sure I sent it right.
I think they bought a bunch of drivelines from someone in the USA because they look new. The guy selling it said to just cut it down if too long. In any case I will not be able to use the driveline if I leave the tiller where it is because I would need to remove 5 inches from the 7 1/4 inch long sliding part, which would leave only 2 1/4 inches engagement. The U joints are so bulky and long compared to the original that I think they are actually made for much higher horsepower.I wonder if Motorcycle Warehouse received a random box of drivelines from the refurb factory and didn't know or care which length matched your tiller. The absence of the special top link components from their tillers might suggest this.
'Some Assembly Required!' (ie leave it to the buyer to figure out what's missing to hook it up).
Thanks for the offer, I'll take it. After tilting the tiller forward to get the shafts parallel I measured the distance and your shortened shaft will work, plus there is plenty of room between the tiller and the tires. Now all I need to do is shorten the top link. If you send me a PM we can work out the shipping details.
Thanks Again,
Eric
That's the tiller I owned. Just in perfect condition. And if I needed a tiller for the YM2000 I would be looking into that model again. Worked really good. We had to dig it out of the back shop, Last one they had. Just came up what was in there. Tom's BA. Helicopter. Super cool..........Eric,
I've been poking around on one of my best hunt for Yanmar stuff on Japan sites. Yahoo.jp
So far this tends to be the closest candidate to your tiller. Since you are missing parts, it's the best I could align by all the pix you gave. It's sitting on a plastic gray pallet too.
ヤンマートラクターYM2010のロータリー 純正RS14... - ヤフオク!
If this is the MATCH to your tiller, I have a program that snags all the images off that page to save. This way, those highres images could assist you in finding the other parts or you can fab something like it.
Oh, if anyone has YANMAR FEVER, then this is the place to enjoy! Type in ヤンマー YM
That is Yanmar in Japanese and YM.
【2026年最新】Yahoo!オークション -ヤンマー YMの中古品・新品・未使用品一覧
「ヤンマー YM」関連の新品・未使用品・中古品が約618件出品中。Yahoo!オークションは、常時約5,000万点以上の商品数を誇る、誰でもかんたんに売り買いが楽しめるサービスです。圧倒的人気のオークションに加え、フリマ出品ですぐ売れる、買える商品もたくさん!auctions.yahoo.co.jp
That tiller is almost identical. The only difference is that the two spring loaded rods that control the back flap are connected to two arms on mine that are missing from the pictured tiller. These arms bolt to the same plates as the H shaped tubular part does, but on the other side of the plates. You can see this in the pictures I posted. So really it is the same tiller, it's just that mine has these two extra parts. And mine is of course missing the wheel assembly. Thanks a bunch for finding the tiller.Eric,
Eric
I could just imagine what the tiller data base is like for Yanmar. Huge I'm sure....... Fredricks calls it a 5' RS1400 series.
Eric
Answering a couple questions you asked. First, mine does not have the handwheel, but instead has a hand crank. All the tillers at the place where I bought mine had hand cranks. Maybe they all were broken off in Viet Nam. Second, I do not have an over running clutch. And I cannot put one on because there is not enough room. There is only 17 inches between the retaining pin grooves in the splined shafts. So that means there is only about 14 1/2 inches between the ends of the splined shafts. I do have an over running clutch on my Ford 9N tractor. I put it on after I used a Bush Hog for the first time. I am hoping there will not be that much inertia in the tiller, not enough to cause problems. If there is then I will need to make extension plates to space the tiller farther back.Eric, forgot or don't remember if I asked you this. Do you have an overrun clutch to run the tiller? Fredricks lists this in their catalog for tiller operation.
OR-660 Over-running clutch, quick disconnect 1-3/8” 6 spline X 1-3/8” 6 spline
Now I'm getting drawn into the tiller strangeness!It's really hard finding ANY images on the web for a Yanmar tiller in action and to use the rear hiller discs in the back the 'correct' way. This might be the best I've seen so far. Howbeit a Kabuta with a Yanmar modified RS1300. LOL
This is a huge time saver for gardeners. From beans, peas, carrots, turnips, potatoes and much more. Getting those tilled up hills in a perfect arrangement is priceless.
