Preventing tractor back flip
/ Preventing tractor back flip #21
The reaction to the drawbar load is trying rotate the tractor about the rear axle in the direction of pushing down on the front axle.
The torque from the engine, acting thru the rear axle is trying to rotare the tractor about the rear axle in the opposite direction.
Traction & amount of each force will determine if the tractor stays on the ground and digs the rears in, flips backwards, or stalls.
/ Preventing tractor back flip #22
/ Preventing tractor back flip #23
See the simplified diagram below.
If "A" moves forward, "E" will rise.
Bruce
/ Preventing tractor back flip #25
Not if "F," the rock, moves too. (I hope that's a rock.)
Wouldnt "F" need to be moving the same speed as "A" to keep "E"down
Something gotta give!!!!!
But Im gonna say Wheelie unless you loss traction(to original post)........
/ Preventing tractor back flip #27
Maybe y'all should ask all the people who have died doing the same thing!
/ Preventing tractor back flip #30
I thought I could find a video example of an actual flip, but can't so far. However, check this tractor pull video out; Note that the tractor is pulling a wheelie the whole time. Certainly they pull from below the center of rotation, yet still get the front wheels off the ground: ‪NTPA Tractor Pull - Jefferson City, MO‬‏ - YouTube
Well.. you proved me wrong... I notice the front only raises at the start of the pull but finally falls to earth at the end of the run. Are the connections to the sled slack? I wonder if the tractors are using a run to get the sled moving and then keep it moving?
/ Preventing tractor back flip #31
Here are lots of real tractors pulling from the drawbar. Most lose traction before the front wheels rise, but a few get the front end into the air.
FARM STOCK TRACTOR PULL
Bruce
/ Preventing tractor back flip #32
DO they have internet access in the hereafter?
I think it depends on which place. It's one of those location, location, and location, thangs. Whichever it is, I doubt the provider actually gives you the speed for which they are charging you (for eternity).
/ Preventing tractor back flip #33
I think a big factor is the torque being transmitted around the rear axle.
/ Preventing tractor back flip #34
/ Preventing tractor back flip #35
That all came about pretty fast..Hard to get in there and stop the engine, before it becomes a Grenade.Hence the kill-switch on a lot of race equipment.
/ Preventing tractor back flip #36
Yes, it can flip over, even if pulling from drawbar lower than axle. I always thought that it could not until ~18 years ago when I was moving some dirt with a tow behind "tumble bug" (~6' wide bucket that tumbles to dump when rope is pulled). The bucket dug in really well, tractor front lifted quickly and I expect it would have went completely over if I had not had my hand on the clutch when it happened. It is scary to ride a tractor (1956 McCormick 650D, no ROPS, no seatbelt, hand clutch) and have the front lift very high. I expected damage but there was none.. (other than my stress level).
Well it appears the evidence is stacked up against me. It's gonna flip.
Now I have to buy that guy a case of beer. :cool:
/ Preventing tractor back flip #38
My neighbor's father says:
"Education is expensive,
no matter where you get it."​
Thanks for the entertaining thread. It was good for our brains.
This thread kept taking me back to when I moved on my property 38 years ago. I had salvaged a bunch of lumber by taking down old buildings and had it all dropped by a dump bed at the bottom of the hill. I had a 100 feet of 3/4" polypropylene line that I was choking bundles of lumber with. I tied it to the front bumper of my jeep and ran the line up and over my plywood roof. I made speed runs up the hill, dragging the bundles. There were some short 5 inch stumps along the way and one of the bundles rammed a stump and the choker slipped down the bundle and lassoed the stump. In a split second, the Jeep was up on the back bumper. I had gotten the clutch in just in time so that it didn't go over all the way. Man, it sure came down hard. I was happy it was on the wheels.
/ Preventing tractor back flip #39
If he's a good sport, he'll share. :thumbsup:
/ Preventing tractor back flip #40
Look at this video. At the start you can clearly see the hitch is well below the axle. Later in the video the front wheels are well off the ground. If the same thing happened at higher speed with bouncing wheels, erratic traction, unpredictable backlash, and other unexpected forces going every which way, then its easy to imagine it could flip all the way.
To me, it somewhat defies logic but see for yourself...
‪John Deere 2 Cylinder Pulling‬‏ - YouTube
2014 GMC SIERRA 1500 (A62613)
2014 GMC SIERRA...
60'' SKID STEER BUCKET (A61572)
60'' SKID STEER...
Caterpillar D5M and D5M LGP Dozer Service and Parts Manuals (A63117)
Caterpillar D5M...
2018 FREIGHTLINER CASCADIA CA125 DC 6X4 T/A DAY CAB TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
2007 Ford F-250 Crew Cab Pickup Truck (A61573)
2007 Ford F-250...
2007 Sterling L9500 Fuel & Lube Y22693 (A62613)
2007 Sterling...
