Preventing tractor back flip
/ Preventing tractor back flip #61
I'm of the opinion that the reason you rarely (if ever) see a tractor flip straight over backwards at a tractor pull, it's because the tires are almost almost always spinning, and they usually add enough weight forward of the rear axle to keep the front end about 3 ft off the ground (for best weight transfer).
Now, I also have the opinion that if you have something hooked to the rear of the tractor and it offers enough resistance, be it attached above the axle or below the axle, and with enough torque from the engine, and if one or both of the rear tires suddenly finds traction and stops spinning, that it can and WILL almost certainly flip over backwards. That may be an uncommon sequence of events, but that's why they call them accidents.
I think there are enough deceased tractor operators that would almost certainly bear witness to that, if they could only speak now. That's all I'll say about it.
It doesn't NEED "opinion" - it is simple physics.
In order for the tractor to flip over backwards the point where the draw bar is attached to the chain would have to move FORWARDS.
Under the conditions specified by the O/P that doesn't happen, or at least he didn't ask whether it would flip if/when the chain breaks (-:
I think the attachment point can't get ahead of the rear axle center line - please explain if I am wrong (-:
That attachment point goes lower and lower to the ground as the tractor STARTS to rotate, it approaches the horizontal plane that the tires are on, but an equilibrium is reached before that.
BTW, I was trained to ALWAYS park tractors "nose in" to the wall of the barn.
a) It keeps driving sleet out of the engine compartment.
b) You ALWAYS have to back them out the next morning, which makes for less of a rude awakening if the tires are frozen to the ground.
/ Preventing tractor back flip #62
Does hooking up a chain short or long make a difference? Short being as close to the object as possible.
I don't think that matters.
As most realize, pulling from a very high point on the back of the tractor would easily flip the tractor over (in most cases). And the lower you move that point, the harder it'd be ... but never impossible, I don't think, given enough tractor traction & power, & an immovable-enough object being pulled.
/ Preventing tractor back flip #63
Reg, you are right, the drawbar won't go forward, the axle will go backwards and the tractor will flip over.
I believe this analysis is a balance of the torques about the axle. If you have a long enough wheelbase (like a dragster) or enough front weight (like a pulling tractor) you will lose traction first or not have enough power to rotate it over. Yes, the distance between the drawbar and the axle also creates a torque about the axle, the lower the drawbar the better. As the front end rises you get less and less anti-flipping torque from front weight until the center of gravity is directly over the rear axle at which point you have no anti-flipping torque from the weight of the tractor. Hopefully before then you've pushed in the clutch, got off the gas or something. Anti-flipping torque, that is my new word for the discussion. :laughing:
/ Preventing tractor back flip #64
Pulling from a high hitch:
Why doesn't the tractor in the attachment flip?
Look at the attachment and the movie. Is the driver that good?
YouTube
/ Preventing tractor back flip #65
Nope;
Not even on a cogged track.
Attend a pull some time.
Watch the front end rise, watch the draw bar lower, see the equilibrium.
You will NEVER see a tractor flip STRAIGHT over backwards at a pull.
If one somehow gets off line - that is different and it will be a weird nasty diagonal sort of thing.
Ever notice the lousy tread and amount of wheel spin these guys rely on to keep from flipping? They want the front wheels off the ground so that all the weight is on the rear driving wheels. But they do not those rear wheels to to grip so good that the engine torque that is twisting the axle will flip them over backwards.
If the back wheels grabbed while the engine's full torque was being applied to turning the rear axle, the only thing left that could rotate would be the tractor.
/ Preventing tractor back flip #66
YouTube
Looks like he keeps working the clutch and bringing the wheels up,and letting the tractor weight coming down to help move the logs.If he didnt clutch it surely he would have went on over.......
/ Preventing tractor back flip #67
If you ask me, this question was settled on page two. If not there, then on page four when he bought the guy a case of beer.
/ Preventing tractor back flip #68
bcp said:
See the simplified diagram below.
If "A" moves forward, "E" will rise.
Bruce
A moves backwards unless you are in reverse.
/ Preventing tractor back flip #69
xtn said:
Some of you keep mentioning a relationship of the axle height to the drawbar. Not important.
You've got force #1, the contact patch of the rear tires on the ground trying to push forward. And you've got force #2, the attachment at the drawbar trying to pull backwards. Since those two forces are not colinear, they result in a torque. Since force #2 is above force #1, that torque acts to rotate the tractor up and over backwards.
The only things that will prevent a backflip are the lack of either enough power or enough traction to complete the job.
xtn
Force 2 acts at the axle. At the ground point, you have the tire lever arm pushing backwards.
/ Preventing tractor back flip #70
I think you are on to something. A lot of times people will use a short chain hoping that the front of whwt they are pulling will lift and not dig in. That changes the direction of the vector the link off the drawbar makes, from pointing along a line below the axle to above it. At that point the front lifts.
/ Preventing tractor back flip #71
I think absent video of a tractor actually flipping over backward, even though his load is hitched below the rear axle, we will still have skeptics. Heck, I'm not a skeptic, but I'd still like to see such a video ... not a guy getting hurt, just proof that it can happen. The tractor in my sample video would of course have a ROPS, & the driver would be belted in :thumbsup:
/ Preventing tractor back flip #73
Again, you can remove the traction issue by regarding it as a cogged railroad track.
The point where the chain attaches to the draw bar does NOT move forwards - unless the chain breaks, or is a lot more elastic than what most of us understand to be "chain".
The rear axle does NOT move backwards.
An equilibrium is reached.
I don't see why folk are not seeing this ~~~
/ Preventing tractor back flip #74
While the theories are bouncing around....It may be worth mentioning that there have been hundreds, if not thousands of cases where tractors HAVE flipped backwards when pulling from a low mounted draw bar. The fact that it DOES happen with some minor degree of regularity SHOULD influence the possible v impossible voting.
Why muddy the waters with experience?
/ Preventing tractor back flip #75
No force #2 does not act at the axle. It acts where it happens. In this case it acts where the chain is attached to the draw bar.
Let's get rid of the whole tractor and just imagine there is a rigid steel triangle running from the drawbar attach point down to the contact patch of the two tires. Three points; drawbar hole, right contact patch, left contact patch. Rigid steel triangle made of angle iron or something. That's what's being acted upon by the two forces. The top point is leaning against a flag pole and loosely chained to it. You grab the lower two points and move them further away from the pole. What happens? As the lower two points are pulled further from the pole, the triangle must incline further back against the pole and the upper chained point must slide a bit down the pole.
Now it so happens that as that triangle gets inclined further back, so does everything else that happens to be rigidly attached to it. Which basically means the whole rest of the tractor, and you too if you're sitting in the seat.
So sure, it has an effect at the axle, just as it has an effect everywhere else on the tractor. That effect can be calculated/predicted at the axle just like it can be for any other point. And the result of any such calculation, for any point on the tractor, is that the forces will tend to make any chosen point rotate backwards. But none of that means the force is acting AT the axle. I mean there ARE forces going on at the axle of course, but not either of the two simple vectors needed to deal with the question asked by this thread.
xtn
/ Preventing tractor back flip #76
I think we are forgetting that there might be an alternate universe where it can't flip over if hooked up below the axle. Just click the heels of your ruby slippers together to get there.
I started reading here with the notion that my tractor was pulling from the rear axle and a lower than the axle hookup would keep me down. I'd never given it any real thought. I used to think that racecars with the center of gravity below the axles didn't flip, though I saw them do it from time to time. All that low center of gravity did was change the traction distribution, but when something stops the tires from sliding, the center of gravity is above the contact patches and it's quite likely going to go over.
/ Preventing tractor back flip #77
Yes of course you're right. Depending upon the height of the draw bar, how far back it is from the rear wheel center line, and the angle the chain is at when pulled tight, there is some point at which an equilibrium must be reached. So technically the tractor won't flip over on it's back completely.
That is... unless you start figuring in momentum and materials elasticity. I mean what happens if the equalibrium point is reached while 2000 lbs of tractor front end is rotating up with some speed?
xtn
/ Preventing tractor back flip #78
xtn
Okay, you know, I have had many many classes in this stuff and done quite well. Some of these "scenarios" you guys are coming up with are quite mind boggling. NO, a tractor does not flip by pure nature. You have to hook the thing up wrong to get it to flip. Most normally the flipping occurs because the pulling causes the heavy object being pulled to lift and exert a reverse torque downward acting at the draw bar. No rolling action on the part of the tire is going to cause the front to lift. If your tractor rares up because the tires are frozen to the ground, you would have to be backing up. Otherwise the torque pushes the front into the ground resulting in the tractor moving forwards. The triangle illustration given earlier is backwards.
Page 2 on the following document gives a free body diagram:
http://www.bae.ncsu.edu/people/faculty/mrburche/BAE200_10/Week9_TK_Ellington/BAE200Traction.pdf
If you observe the forces on that diagram Rmr is the actual moving force, and Rtr is the reacting traction force. Rtr is NEVER larger than Rmr. They are at most equal, which means the tractor will not be slipping. That diagram was drawn to illustrate traction forces, but they did add something to it wich shows why tractors flip. If you look at the very back there is a vector called the line of pull. Notice that it is at an angle? That is what I was talking about above. If you want to look at the situation where the nose lifts, you set the origin to the contact point of the ground and tire. When you do that, there is no reason for the nose to lift due to forward tire rotation, unless you have additional forces reacting to the forward motion of the tractor. In that case, you have to have a backwards torque acting around your ground contact point that exerts a torque greater than your forward driving force x the height of your axle + the mass of your tractor x the horizontal distance from the ground contact point to the center of mass. Now, the reason that it appears that the tractor flips it's self over is that the torque is usually created as a resultant force of the load pulling back against the tractor frame. Add that to the fact that the horizontal distance from the ground contact point to the center of mass shrinks very quickly once the front rises off the ground, and you can see why it looks like they flip easily.
Confused?:confused2::confused2:
/ Preventing tractor back flip #79
I am more confused now than when I started this blasted thread!
2015 SUNDOWNER 25 T/A ENCLOSED TRAILER (A67714)
2015 SUNDOWNER 25...
2023 JCB 3TS-8T TELESKID (A65053)
2023 JCB 3TS-8T...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
Yamaha 150 V6 150 2-Stroke (A66738)
Yamaha 150 V6 150...
2014 MAC FLAMELESS HEATER (INOPERABLE) (A68842)
2014 MAC FLAMELESS...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
