Pressure Washer Recommendations?
/ Pressure Washer Recommendations?
. Always use non ethanol fuels, either remove the ethanol yourself or purchase the premixed non ethanol 2-stroke chainsaw fuels. These fuels can be stored for upto 5 years, compared to 4 months for ethanol fuel. And the additional lubrication in these premixed fuels benefits your small gas engines.
In the case of the Stihl 600 PW, Stihl sells stabilized 93 octane ethanol-free 4 stroke fuel by the gallon container. Purchase one at the time of PW purchase and they double your warranty to 4 years. For my limited use 2-3 times a year, I'm OK paying the premium all the time to know the fuel is good.
/ Pressure Washer Recommendations? #23
I actually gave that same electric model to my daughter, it's perfect for her townhouse. I borrowed it this summer to clean a 12' landscape trailer and while it did an OK job it seemed to take forever as I had to hold the tip very close to the work surface due to the limited pressure and volume. Plus, it states right on it not to use with an extension cord (presumably due to the GFI) and I need to be able to work 100' from my house.
thanks
/ Pressure Washer Recommendations? #25
Most important thing is for it to have a cat type pump, not axial. Rigid makes a nice one, with Subaru engine
Those would be leftover pressure washers since Subaru shut down their small engine and industrial tool line in October of 2017
/ Pressure Washer Recommendations? #26
Washed equipment today (shirtless) with the return of summer. Blizzard on weekend! Annoys me, how the cold pressure washer blasts grease onto othr areas of the machine. Also, certain greasy areas around zerks are just nasty and the washer won't touch them at all.
Bought a big used GERMAN Diesel Fired (WAPP) electric pump, washer at auction a year ago, cheap, and have a new a thousand dollar steam coil sitting in a Niagara Falls NY shipping depot, since February, that I can't get! I have an old Steam Genny, so dangerous, I don't care to use it. I have never used a HOT water pressure washer and was looking forward to this project.
/ Pressure Washer Recommendations? #27
I have a Stihl pressure washer . Gas. It starts first pull after sitting in the basement all winter. My neighbor uses it when he comes up to his vacation house. He loves it too. And if something goes wrong the place I bought it can fix it or get parts, unlike the big box stores.
Not sure what you mean.
Parts for my box store Briggs and Stratton Pro 3400 with Annovi Reverberi pump after 14 years are still easy to get. (not that I ever needed any)
Brigg Vangaurd 9 hp engine parts are easy to get, same with Annovi Reverberi XMV3G32pump.https://www.amazon.com/Pump-Piston-...rds=xmv3g32&qid=1604536578&sr=8-8&tag=mh0b-20
https://www.amazon.com/AR-America-X...rds=xmv3g32&qid=1604537465&sr=8-1&tag=mh0b-20
/ Pressure Washer Recommendations? #28
You will LOVE your hot pressure washer when you eventually get it running!
I don't use my cold water washers on anything greasy....just a waste of time and effort!
Very frustrating to just blast the grease from one place to another.
/ Pressure Washer Recommendations? #29
I've had exactly two pressure washers in 30+ years. First one was a Craftsman that cost me $350 (with coupons lol). It had a Reverberi pump on it (all brass) and worked excellent for at least 10 years. But the pump blowoff valve (releases the pressure when you let go of the handle) quit working so the only way i could use it for a year or so (or 5) was to start and run continuously. It worked that way for a while but I eventually found a replacement unit from Home Depot. A Excell 2500 unit with one of those new fangled push-pull motion pumps. It worked good for about another 10 years and started doing the same thing as the first one with the blow off valve not working. Eventually the pump "disintegrated" into chunks on the floor. But, with it there were replacement pumps available as a "kit" to repower the water pump head. I replaced the assembly and it's still working fine with the Honda 5hp engine on it. As for the first one I eventually did get replacement parts to fix it and it still is around but at our family farm. I haven't used it lately so don't know the status but it's still around.
So, if you have a need to repair one of these things as they engines seem to keep going forever, you can get parts to repair them it seems. Especially the cheap ones as people want to keep them going and they sold thousands and thousands of them.
Steve
/ Pressure Washer Recommendations? #30
@JohnKN - have a need for a generator? For those times when you need to be further away, run the PW off the generator.
Power isn’t so much a problem, I have portable generators, but I don’t have a portable water source, so hose is my limiting factor. I guess with a 300g tote and a generator I could PW most anywhere.
/ Pressure Washer Recommendations? #31
I've got 2. A 5hp 2000psi Honda gc engine. Use it on most things. Then there's the northern tool 4000psi 13hp honda beast. The 4000psi only gets used if I have a lot of surface cleaning. Its fast and strong and will wear you out. I do reccomend spending a little extra and you get a belt drive unit. They are gear reduced pumps that spin at 1800rpms and last a long time. Both my washers have cat pumps and I've had them many years
/ Pressure Washer Recommendations? #32
If you cleaning flat ground surfaces get a surface cleaner. They cut your time down 75%
/ Pressure Washer Recommendations? #33
You couldn't GIVE me a gas powered washer. I have a quiet commercial electric unit for maybe twenty five years already with Triplex CAT pump, LEESON Motor, bought used for $200.00!. No gas issues either.
Me too!!!! Gas sucks for several reasons, learned the hard way.
/ Pressure Washer Recommendations? #34
Said how much I love my commercial electric pressure washer. Now it's stalling and blowing the breaker. We have very hard water and I suspect the relief valve is sticking. It only gets any love when it gives trouble.
New/Unused Spirit Electric Tricycle (A65583)
New/Unused Spirit...
2005 International 5900i T/A Gardner Denver Kill Truck (A64194)
2005 International...
2014 INTERNATIONAL PROSTAR+ (A65643)
2014 INTERNATIONAL...
(2) Caterpillar Skidsteer Tires (A66408)
(2) Caterpillar...
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
Stout Buckets XHD84-6 Brush Grapple Skid Steer Bucket (A65640)
Stout Buckets...
