Pressure Washer Recommendations?
/ Pressure Washer Recommendations? #1
Johnkn
Laplata, MD
Kubota LX3310
I'm looking for another gas powered pressure washer. At age 65, if I need a big job done like washing my house, etc. I generally pay a pro to do it, but 2-3 times a year I might want to do something myself. My last 2 in the $500 price range were both POSs. I'm willing to spend $800-1000 for a washer that will last. I always maintain them properly, never start them dry, cycle stabilized fuel and pump lube / winterizer through them before winter storage, but the last 2 were terrible and a struggle to start and run, and they didn't last. Suggestions? thanks
/ Pressure Washer Recommendations? #2
You couldn't GIVE me a gas powered washer. I have a quiet commercial electric unit for maybe twenty five years already with Triplex CAT pump, LEESON Motor, bought used for $200.00!. No gas issues either.
LOL I don't disagree, my last 2 were a POS. The 120v electric PWs I've used and seen generally state they should not be used with an extension cord. Mine needs to be more mobile in some cases. thanks
/ Pressure Washer Recommendations? #4
I have both gas and electric.
The gas is a 13HP Honda engine, with a 4000 psi triplex pump.
Nice unit, but I don't use it, and need to sell it this Winter.
My electric one is old, is HOT, and is only 1000 psi, but it is the best for me.
Hot + electric !!!!
/ Pressure Washer Recommendations? #5
@JohnKN - have a need for a generator? For those times when you need to be further away, run the PW off the generator.
/ Pressure Washer Recommendations? #6
I too have only occasional use for one, and really didn't want to have to deal with another gasoline engine. I started with a big-box electric, which was puny, failed after a year, and was unrepairable.
So I went looking for a real electric pressure washer and found this one:
Portable Industrial Electric Power Washer | Cam Spray
It is available with various cart configurations, and in 240-volt models. I find the 20-amp 120-volt model works fine for occasional use, and can be used anywhere on my place with 120-volt outlets. Obviously won't work in the middle of a field, but with an extension hose does have quite a bit of reach.
I like that it's American made, has parts available, and has very helpful tech support available by phone.
You can buy direct, but I found it on an online dealer, and may be available from local dealers if you don't live way out in the sticks like we do.
/ Pressure Washer Recommendations? #7
Well, as much as I hate noisy GAS engines, if you do need portabliity, I would have to conceed that the gas engine washer is best.
Hi, thanks, I have a Honda Generator.....
/ Pressure Washer Recommendations? #9
Most important thing is for it to have a cat type pump, not axial. Rigid makes a nice one, with Subaru engine
/ Pressure Washer Recommendations? #10
CAT is a brand of Triplex pump. Italian.
/ Pressure Washer Recommendations? #11
Well, I recommend Karcher... both petrol and electric. Honda engine, brass fittings, excellent quality.
My electric Karcher hasn't let me down.
The choice of the Royal Australian Air Force for aircraft wash-down. Unknown if that includes the Fleet Air Arm or Army Aviation, but I wouldn't be surprised due to commonality of equipment.
/ Pressure Washer Recommendations? #12
I've owned a Briggs and Stratton Pro 3400 for 14 years.
3400 PSI, 9 HP Vanguard, Annovi/Reveberi tri plex pump (pump made in Italy)
Nice unit.
/ Pressure Washer Recommendations? #13
Nice unit.
I have a Stihl pressure washer . Gas. It starts first pull after sitting in the basement all winter. My neighbor uses it when he comes up to his vacation house. He loves it too. And if something goes wrong the place I bought it can fix it or get parts, unlike the big box stores.
Thanks for the suggestions, I’ll figure this out. Thinking about the Stihl too as I have a good relationship with my local dealer and they happen to be my Kubota dealer. :thumbsup: Thanks
/ Pressure Washer Recommendations? #15
Four stroke? What does Stihl use for an engine?
The Stihl 600 uses a 4-stroke 7hp Kohler engine. 3200psi/3GPM. Standard 2 year warranty becomes a 4 year warranty if you buy a gallon container of their fuel once at the time of product purchase. MSRP is about $950 and if there's an issue I can take it to them a few miles from my home for service.
The Simpson PW I purchased 3 years ago and used 30 minutes before it expired had a Honda engine, but proceeded to blow half it's pump across my garage floor as I was cleaning it about 30 minutes into the job.
/ Pressure Washer Recommendations? #18
I've owned several homeowner duty electric, a commercial class electric, and a commercial class gasoline powered unit.
The commercial class units with comet pumps have performed for decades. Biggest problem for me is hard water and particulates getting into the unloader valves. A metal water filter screen is not enough protection.
The homeowner class units are all POS and were decent for about a season. Avoid units where all the components are hidden and un-replaceable.
Pay attention to the duty cycle on the pumps. You get what you pay for.
/ Pressure Washer Recommendations? #19
Gas powered pressure washers experience the very same issues as gas generators do: ethanol based fuels are dangerous to any small gas engines that sits unused for 4 months or longer. Corrosion and pitting of the carburetors results in just enough damage, that hard starting and unreliability becomes severe enough (even to Honda's) that owners become frustrated. Always use non ethanol fuels, either remove the ethanol yourself or purchase the premixed non ethanol 2-stroke chainsaw fuels. These fuels can be stored for upto 5 years, compared to 4 months for ethanol fuel. And the additional lubrication in these premixed fuels benefits your small gas engines.
/ Pressure Washer Recommendations? #20
Don't be fooled by specs. I suspect many are fudged for marketing purposes, like the HP ratings on shop vacs. I have a 2hp electric pressure washer that does 1000 psi (CAT TRIPLEX Pump) that will perform about the same as any typical do it yourself car wash. I never, ever had any thought in the twenty five years of cleaning all manner of stuff, that I wished it had more pressure. Mostly, I have to be carefull of not destroying stuff.
2010 Mercury 15HP Tiller Four Stroke Outboard Boat Motor (A61574)
2010 Mercury 15HP...
UNUSED IRMC HIGH END MASSAGE CHAIR (A64281)
UNUSED IRMC HIGH...
UNUSED MOWER KING (A64281)
UNUSED MOWER KING...
2025 30in. Pallet Forks and Frame Mini Skid Steer Attachment (A61572)
2025 30in. Pallet...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2008 Ford F-250...
