Practice Removing Your FEL
/ Practice Removing Your FEL #43
I got double practice on mine... Last weekend was the first time I used the tractor and i wanted to see how everything worked and how it handled with and without the loader on.
I had it in my shop and was going over the manual and took it off with no issues. Time to try it out without the FEL now...that is the point that I remembered I had backed in!!
Hook it up turn around and repeat. It was easier the second time around too!!!
/ Practice Removing Your FEL #44
Now that...that was a senior moment!!!
/ Practice Removing Your FEL #45
Roy-
I agree with you 100% - I bush hog with my L3830 with the loader off and I put 220lb of suitcase weights on the front end of the bumper. This makes the tractor very stable and I can mow near fence lines without having a loader bucket and/or arms extended over my head. There is definitely a learning curve with removing the loader but if you keep at it, it gets easier and easier. I would strongly recommend front end weights to balance the bushhog on the rear ( my 5 ft woods is about 600lbs) - Mike
/ Practice Removing Your FEL #46
Haven't done that yet...but give me time.
/ Practice Removing Your FEL #47
I had the same thing happen. Was a pretty good duh moment. I chickened out and just left it on. Needed to kill some time in a downpour, so I thought I'd play with it. It came off pretty good, never had the guts to disconnect the lines though. I use my loader nearly daily, and at this point don't own or have access to other implements. No need to have the loader off, but I agree with BP, probably a good thing to be able to do. I haven't driven my tractor without it. Would probably feel like a sports car. :laughing::laughing:
/ Practice Removing Your FEL #48
I'm guilty as charged...I've never had my FEL off and mow with my MMM weekly during season...I have some slope at the end of my field so I lower the bucket to almost ground height have never had the pucker factor kick in...I'd let a trained monkey do it, but they're outlawed here in Orygun.
Don
/ Practice Removing Your FEL #49
Just took mine off for the first time. I didn't time it, but my gut says 3-4 min.
/ Practice Removing Your FEL #50
Don
I have found that if you put a John Deere hat and sun glasses on them, no one pays much attention:)
No offense intended as I have a John Deere hat and sun glasses and no one pays any attention to me either.
/ Practice Removing Your FEL #51
I am just now getting to the dangerous stage. Thinking that I have enough seat time to be good at it. Then along comes a post and I realize that I've never taken off the FEL. First impression - my tractor looked naked!!
Putting the FEL back on was a little bit more of a challenge but probably the third or fourth time I'll get the hang of just how to hit the sweet spot. Thanks to all for both the encouragement and tips.
/ Practice Removing Your FEL #52
I've had my tractor (BX1500) for over 6 years now. I leave the FEL on in the winter for snow/firewood duty. In the summe,r the tractor mainly mows, but does other things too, often using the FEL.
So, each spring, I am "reminded" to take the FEL off when mowing. It seems that each spring I say I'll just be careful and mow with the FEL still on.
This year I was reminded by the dog fence. Last year it was a rock wall.
Anyway, I have now started taking it off to mow, and putting it right back on when I'm done mowing. This way, it's always ready to go if I need it when doing a non-mowing chore. I keep in practice taking it off and putting it back on. The FEL doesn't have a chance to settle over a few weeks of non-use, which can make it hard er to put back on.
It adds to the mowing time a small amount, but seems to work.
We'll see what I do next spring.
/ Practice Removing Your FEL #53
That's one thing I like about the Kubota, the loaders are so easy to take off and put on. Just do it on a flat area and put a board under the stands.
/ Practice Removing Your FEL #54
OK, once past the first time I found that the technique I missed was getting the tractor lined up with both sides before performing any further steps. Now, thanks to the prompting of this group it is a good, efficient and straightforward (less intimidating) process.
Thanks again for the encouragement!
/ Practice Removing Your FEL #55
... my tractor looked naked!!...
LOL! I will say that when I went from a sears riding mower to a Mahindra 3316, my wife thought the tractor was way too big. If I take the FEL off, it looks a whole lot smaller.
Montyhp
/ Practice Removing Your FEL #56
I had a bit of practice trying to re-connect the FEL on Saturday
man! what a pain, I removed the FEL on Tuesday to re-paint it to match the tractor,was very easy to remove, simply let the bucket down flat, drop and pinup the stand/legs remove 4-bolts loosen the saddle bolts and back out from it, took approx 10 minutes,
Although yesterday while attempting to hook it back up was not so easy of a task, it took me all of 2 hours, first of all the hydraulics had extend causing the rear of the loader arms to drop 6" to low to pull under, so I had to jack it back up, Only it wouldn't hold on its own, once I let the jack back down, and you cannot simply scotch up on the loader because it has to be completely cantilevered over in order to drive the tractor back under, so then I go for the cherry picker to try and lift from the tops side, Only now I have the legs of the Cherry picker to have to drive the front tires over and still causing a problem for hooking it up, I finally had to use a scaffold built over the top with a I-beam and cable it up with a com-a-long so's could drive under,and even then if I would had need to crank the com-a-long 1 more click it would not have went high enough for the tractor to clear, :confused2:
Back when I first bought this used FEL the person had it wenched to the trunk of a tree and at that time I kinda wondered about why was that? Ha! now I know why :cool: and that will be the way i remove it next time, so much for the ingenious factor idea of having built in stands for the FEL , they not worth a Hoot! :confused:
/ Practice Removing Your FEL #57
The Bushhog loader on my old Kubota went on/off pretty easy. Usually left it on though; needed the weight to counterbalance the mower. Otherwise, I had to remove part of the tractor mount loader frame, and hang a couple suitcase weights.
My new-to-me NH TC40D, is too big for my existing trailer; I can barely fit the tractor minus loader, while the rotary mower is attached. The TC40 is no problem for weight, but is just long compared to the old smaller B series Kubota.
The 17LA QA loader popped off very easily, easier than the aftermarket Bushhog on the Kubota(which was real easy too). Biggest thing I found, is to start on a flat, level work area.
The thing when I leave the loader on the NH that is odd, is with Supersteer(front axle pivots for a super tight turning radius), the bucket moves at a diferent angle when the axle starts to move. Wierd to get used to...
Generally I leave the loader on, to push stuff, carry tools ect. There are a couple trees with bucket marks on the property though...
/ Practice Removing Your FEL #58
I would like to try and mow without the FEL on but the trails I use to access the fields I mow are steep. I would be fine wihout the FEL on most with the exception of one. I need the weight of the FEL on the front to prevent flipping over end while coming up that hill, especially with the RFM on.
I use the FEL more often than none so its not worth taking it off and adding front weights to compensate.
/ Practice Removing Your FEL #59
I have a similar situation on one of the sections of my property. I was able to go up by putting the 3-point equipment on the ground and the raising it on the way down for added traction. I haven't tried it yet with my new tractor.
Of course all tractors are different, but I have backed up hills with FWD if the front was a little lite.
It seems like I am always pushing something out of the way, so I usually keep my FEL on; gonna try it without it the next time though as I am still getting acclimated. I am used to my other geared tractor and its controls.
/ Practice Removing Your FEL #60
taking off the FEL is pretty easy What's a bit tricky is putting it back on.
