Pole barn started
/ Pole barn started
Thanks Eddie, I was looking for a traditional look and I'm happy with how it turned out. The people at all the electrical suppliers recommended what the called mobile home feeder. It's four #2 aluminum wires and a 100 amp box. More than what I wanted to spend but I will have flexibility in the future. The wood is red oak for the siding they ran out of oak so I had to use maple in the stalls. I plan to use a light red cedar sealant once the wood dries. My hope is that it pops the color in the oak, we'll see. I took Friday off work and buried the conduit and water lines almost 400 feet needless to say I didn't have any trouble sleeping Friday night. I ended up renting a ditch witch cause I wanted the water line deeper than the subsoiler could put it
/ Pole barn started #53
I've used mobile home feeder before, but it was not rated for burial, conduit or not. I guess make sure you buy the right wire no matter what. 2-2-2-4 aluminum is good for 90A as a branch or 100A as a feeder.
If you pull through conduit, it will end up being separate wires with a W rating, which is easier to pull anyhow. Generally, bundled or jacketed stuff is for direct bury or in-wall only.
2016 Ford F-150 Crew Cab Pickup Truck (A59230)
2016 Ford F-150...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2014 Ram 1500 4x4...
Deere 331G (A53317)
Deere 331G (A53317)
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
2023 Ford Expedition SUV (A59231)
2023 Ford...
2011 Ford F-750 Etnyre 2,000 Gallon Asphalt Distributor Truck (A59230)
2011 Ford F-750...
