Pole barn started
/ Pole barn started
Haven't updated in a while. The weather has been bad and the progress slow. I did reach a milestone today, got the siding up on all four walls, now the hard part. I dread the up and down ladder trips to finish the gables. The wood is better than expected I have used three bundles and have two left so I should have plenty to do the stalls.
/ Pole barn started #42
Looks very good! Are you going to run the same wood at the top of the wall under the lean-to?
/ Pole barn started #43
Looks great!
Should be ready just in time for spring.
/ Pole barn started
WM, yes I plan to use the same wood for the area above the lean to wall. I will do that last so I will be able to use the short pieces left after the siding and stalls arte done. I hope to have the horses in it by May so I hope I can get the barn finished so I can get the fence up.
/ Pole barn started #45
I'd say you are making good progress and it looks great.
/ Pole barn started
Got one gable end sided will post sme pics once I get the other one done. I"ve got a couple of questions. The two sliders have gaps around them and when I open them they hit the siding and they are free hanging, I can push the bottom of the door out. Is there a kit out there I can buy to seal the doors and secure the bottom and keep it from hitting the side of the barn? One more. What would do to bring the barn floor up to grade, there will be horse stalls on one side and tack/storage on the other. Concrete is not on the budget right now. Thanks!
/ Pole barn started #47
Is there a groove/track in the bottom of the door frame? I have seen barn door hardware (some with rollers, some just a guide) meant to keep the bottom of sliders from swaying. There are zillions of different hardware doodads for sliding barn doors. Worst case, you could bolt some track on the bottom of the door and then put a guide on the ground. Could be as simple or fancy as you want.
I have a barn set to start in May. If I don't have budget for concrete, my plan is to put down plastic, then gravel (probably #57 or #78, which self compact with minimal work), and then crusher run. That should work fine for utility use, but not sure if it would be OK for horses though. May not be good to stand on, and certainly would not be easy to clean.
/ Pole barn started
Have updated in a while, spring has its chores that take priority that I have been working on so the barn took a backseat. Got the exterior done and the stall dividers in also got the floor rough filled with a sand clay mix that has packed well. I will top that off with about 3 inches. I thought it best to run the water and electricity before I finish off the stalls and tack room. Couple of questions. Its 170 feet from the breaker box in the house and the barn what size wire do you guys suggest I will not be welding out there but will ocassionally run a miter saw and small air compressor. I was thinking 10/3
/ Pole barn started #49
What amp load? If at 120V, you would probably want #8 copper or #6 aluminum to carry 15-20 amps with acceptable voltage drop. If less amperage needed, you can go lighter. There are online voltage drop calculators that can help you spec the wire. Ideally, you want less than 5% voltage drop at the rated amperage.
I am running #6 aluminum to my barn, which will let me support 15A loads. In fact, the barn builders are using the wire as an extension cord right now, since it's not buried yet. They have run multiple saws and have a compressor kicking on periodically and we haven't had problems. That's hanging off a 20A breaker and GFI outlet right now.
/ Pole barn started #50
That sure came out looking nice. I really like how it has a timeless look to it. You could have built it fifty years ago, it looks like it's been there forever!!!
Congratulations
Eddie
/ Pole barn started
Thanks Eddie, I was looking for a traditional look and I'm happy with how it turned out. The people at all the electrical suppliers recommended what the called mobile home feeder. It's four #2 aluminum wires and a 100 amp box. More than what I wanted to spend but I will have flexibility in the future. The wood is red oak for the siding they ran out of oak so I had to use maple in the stalls. I plan to use a light red cedar sealant once the wood dries. My hope is that it pops the color in the oak, we'll see. I took Friday off work and buried the conduit and water lines almost 400 feet needless to say I didn't have any trouble sleeping Friday night. I ended up renting a ditch witch cause I wanted the water line deeper than the subsoiler could put it
/ Pole barn started #53
I've used mobile home feeder before, but it was not rated for burial, conduit or not. I guess make sure you buy the right wire no matter what. 2-2-2-4 aluminum is good for 90A as a branch or 100A as a feeder.
If you pull through conduit, it will end up being separate wires with a W rating, which is easier to pull anyhow. Generally, bundled or jacketed stuff is for direct bury or in-wall only.
2023 Dodge Durango AWD SUV (A64557)
2023 Dodge Durango...
Firestone Bolt On Duals 14.8-38 (A65640)
Firestone Bolt On...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
211299 (A62131)
211299 (A62131)
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
