Please Help RK 24 Rust issue
/ Please Help RK 24 Rust issue #1
John Tractoring
Estill springs, TN.
none
A few days ago I was about to buy a RK 24 with loader and backhoe from my closest Rural King. However upon further inspection under the tractor I found this (see pictures) Is this a reason to NOT buy this tractor? All of the RK 24's on the lot were rusted like this but the only one with the backhoe was the worst. Should I stay away from these tractors at this particular location or what? Everything else seems yo look fine. Please advise me and Thanks For your input.
/ Please Help RK 24 Rust issue #2
What part are we looking at? For some types of parts, rust would be of zero concern. But can't say without knowing what we're looking at.
/ Please Help RK 24 Rust issue #3
Guessing that's the close end of the drive shaft that goes to the front axle.
Looks like my truck's brake drums - unpainted and expected to rust on that side to no ill effect.
/ Please Help RK 24 Rust issue #4
That tractor has obviously been sitting around somewhere for a good while.
I would check carefully to see if there may be any other issues.
Its the the close end of the drive shaft that goes to the front axle underneath the middle of the tractor like ning said.
I have not found any thing else on it that looks bad to me just what ive found underneath it in the pictures. The rust is pretty thick and all the rk 24's on the lot has this rust in the same place. Im not completely new to tractors I've had two new mahindra's prior (which TYM also built mostly) I know your gonna find some rust issues on any tractor thats been setting out but this has really stuck out like a sore thumb to me. I wanted to get some feedback from you guys that have more experience with tractors in general and especially the RK24. So provided that I dont see anything else that looks bad would you all say yes to buying it or would you say look elsewhere? Thank you for the help.
/ Please Help RK 24 Rust issue #7
But it and treat the rust with some spray lube or spray rust treatment.
/ Please Help RK 24 Rust issue #8
After you drive it a while, that area will be covered with mud and miscellaneous organic debris and you won't be able to see a little surface rust.
Thanks for all the replies. I have since just about sold myself on a Branson 2610 except for when I test drove the similar 2400 (they didnt have a 2610 on the lot) I was vey disappointed in the loader speed (curl and dump) it was slow as christmas. My last two tractors were a mahindra 2538 and then a 3540 37-40HP I think they had a GPM of around 11.0 give or take. The little Branson has 8.2 from what Ive been reading most of the 25 hp tractors have GPM of 6-8 but Ive seen smaller tractors being used and none of the loaders moved as slow as that Branson did today so IDK.
/ Please Help RK 24 Rust issue #10
Check lifting capacity of the Branson. There’s sometimes a compromise between lifting force and speed and if the Branson is rated higher the slower speed might be worth the compromise.
Thank you everyone for your input. I decided to move on to either a Kioti CX2510 Hydro TLB Vs a Kubota B2601 Hydro TLB. Same price, same deal, $0 down $0 for 84 months. What would your opinions be on these 2 models. The Pros and Cons. I would probably be happy with either tractor. But on paper the Kioti beats the Kubota except for the 3 range on the Kubota. I'm going to also post this in the general comparisons thread also.
Thank You all for the help
/ Please Help RK 24 Rust issue #12
Interesting to see that. I am looking at buying the same model. I'm not sure what part I am seeing in your pictures but I probably wouldn't be concerned about it. I would be looking at the fit and finish of the rest of the tractor. Rust is rarely ever our friend but also not always a big concern depending on where it is located.
/ Please Help RK 24 Rust issue #13
If you have a Yanmar tractor dealer in your are test drive
some of their tractors
willy
/ Please Help RK 24 Rust issue #14
willy
Test drive a Kubota. They are the best small to medium size tractors for a reason.
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
2006 Mack CV713 Flatbed Truck (A62679)
2006 Mack CV713...
KUBOTA SVL97-2 SKID STEER (A62129)
KUBOTA SVL97-2...
Miscellaneous Mini Excavator Attachments (A61572)
Miscellaneous Mini...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
