PEX & Kinks
/ PEX & Kinks #21
I might add that I never have tap water or any treated water in mine. Only Cryotec PEX solution. Heats and cools my shop.
/ PEX & Kinks #22
And pex last a long time. It doesn’t go around failing all the time like some people seem to believe.
Exactly! Most of the housing around here is plumbed with pex, has been for nearly 30 years and I don't hear of anyone complaining about leaks.
/ PEX & Kinks #23
I would take properly installed PEX over copper for most work any day. The ability to pull runs without joints and the inert-ness of PEX make it far better than copper. Sometimes you need the durability of a hard metal pipe, especially when exposed in areas where damage can occur. In those cases, copper makes more sense. And for reference, I sweated copper for all my air lines in my shop, so I am not anti copper at all. It is just that PEX is actually a better material for water supply, in most cases.
/ PEX & Kinks #24
Properly installed PEX is ok for RVs and mobile homes that don’t have a long life expectancy anyway. I would never use it in a permanent home. Copper is more expensive but will last much longer (70+ years) if installed properly.
I just pulled about half the copper out of my house. It took me about a day working by myself. Copper would have taken considerably longer. The line to the cold water on the kitchen sink now has no elbows. With the copper there was six 90 degree elbows.
The next water project is going to be to run a 3/4" line the the hot water tank and to a manifold on the outlet side. Then most of the copper lines in the house will have been replaced. Yea!!
Also I've never experienced a leak with pex. I can't say the same for copper.
/ PEX & Kinks #28
I would NEVER use sweated copper for air lines in any shop where the static pressure exceeds 130 psi (which mine does), sweated copper lines are a grenade waiting to explode and the shrapnel from any failure if you are in the 'bleed zone' can kill or cause you great pain and discomfort.
My entire shop, both the front bay as well as the back bay is all run in black iron pipe with convenient drops and terminates in a WOG valve to drain off any accumulated condensation.
My static air line pressure is set at 140 psi though I could run 175 psi but I don't. The higher the static pressure is, the more drop out condensation is produced in the air lines and water in air tools is a big no. I actually have a an IR air dryer on one compressor as well as the built in air dryer on my screw compressor and I still religiously drain the drops when I use them. I use a lot of compressed air when I'm plasma cutting parts on my CNC plasma table and to that end, my plasma cutter also has a 'Motorgard' cannister filter post inlet on the plasma cutter. You NEVER want to have any condensate in the air stream in ANY plasma cutter as it will quickly destroy the consumables in the plasma torch (consumables aren't cheap) and will degrade the cut as well as destroy the air valving in a plasma cutting unit.
When it comes to shop air, it's always delivered CFM and not static pressure and I have CFM in spades. With both the screw compressor running as well as my 7.5 horse Quincy on line, I have over 40 CFM free air delivery at 140 psi. No air operated tool, impact or otherwise requires any more line pressure than 140 psi to operate at maximum delivered power, in fact I can get maximum delivered power from any air tool at 100 psi but I also run high flow fittings and connects on all my air tools and I always lubricate them prior to use with IR air tool oil. With any air tool, it's all about delivered CFM and using conventional fittings versus high flow fittings will impede that air flow.
Been doing this a long time now, over 20 years or so.
/ PEX & Kinks #29
I might add that when I ran my air system, I purchased all my black iron pipe in mill lengths (20 feet) and threaded everything myself. I own a Ridge Tool pipe threading unit so cutting NPT threads was easy and I purchased all my fittings from a local industrial supplier. All my main runs are in 1.5" black iron and the drops are 1". You can rent a pipe threader at just about any tool rental outlet.
/ PEX & Kinks #30
One thing to always keep in mind as well and that is, the higher the static pressure ANY compressor is set at, the less time said compressor will last. The reason is, the higher the delivered pressure is, the more heat any compressor will produce and the higher the delivered pressure is, the faster the reed valves in the compressor head will carbon up and require maintenance or valve replacement. Of course that don't apply to a screw compressor as a screw don't have reed valves but all conventional reciprocating compressors do. How they work. I only use my Quincy reciprocating compressor when I require maximum air delivery when running the plasma table for extended periods as plasma cutting always requires lots of air delivery at the required pressure and it has to be clean, condensate free are as well. I actually have 4 air compressors all plumbed into the air system but 2 of them are only used for their receivers to maintain constant air flow. The more air storage available, the less the compressors cycle and the less they cycle, the longer they last between servicing.
Was in an industrial shop the other day and took a gander at their delivery system which was in, of all things, plastic pipe and I thought to myself, that is a bomb waiting to go off. Plastic solvent weld pipe especially is prone to getting brittle and failing with the presence of heated air (compressors do raise the temperature of the delivered air, it's part of the mechanics of air compression). Why I run condensate refrigerated dryers on my air system as close to the compressors as possible. I recommend the IR dryers, 100% turn key with automatic condensate drains and my compressors also have automatic condensate drains as well.
/ PEX & Kinks #31
I deem you nucking futz... I would NEVER use sweated copper for air lines in any shop where the static pressure exceeds 130 psi (which mine does), sweated copper lines are a grenade waiting to explode and the shrapnel from any failure if you are in the 'bleed zone' can kill or cause you great pain and discomfort.
Interesting, since even type M copper tubing has a working pressure rating of over 280 psi (1 in diameter). Even 3 in diameter has a working rating of over 200 psi.
/ PEX & Kinks #32
Keep in mind that the weak link will always be the sweated connections which aren't ever an issue with NPT connections. Considering the cost of copper alloy piping and fittings compared to black iron pipe today, I would surmise the cost to be about the same not including the cost of the pipe threader of course. The only copper in my entire system is the line that goes from the high side of the Quincy to the receiver and possibly the inter cooler but that is painted so I'm not sure about that.
/ PEX & Kinks #33
What hasn't been mentioned, Pex can take freeze cycles better than copper. Due to someone else's builder doing an improper install, my Pex pipes froze several times, no issues... usually took 3 days of temps over 35 to thaw...
/ PEX & Kinks #34
And I would deem you 100% wrong. The Fortune 100 company I work for uses grade L copper for all their industrial air lines, and so did I. Now if you were talking about PVC becoming shrapnel, then I would agree. But Grade L copper is well within the working pressure range for this and is not a "shrapnel hazard" like you claim. If the professional pipe fitters in the labs and plants use it, with all the potential liability that a large organization is so scared of, then it is perfectly acceptable in my shop.
/ PEX & Kinks #35
Whatever. I do what I'm comfortable with and what I know works safely in my situation, what you ascribe to and what I ascribe to distills down to your opinion, versus mine. What a forum is all about, opinions and I would never demean anyone on here for that like you just did. I find that to be less than a mature reply, in fact, much less.... and I was not referring to the copper piping itself, but the sweated copper joints and if they were properly fused or not. You need to go back and read my comment, not that I would ever use copper tubing in that application, because I would not.
I'll leave it at that.
/ PEX & Kinks #36
Well that is par for the course for you. You were the one who was insulting and name calling to begin - out of the blue - and I was far more polite in response than you deserved. And now gaslighting in response.
I gave you FACTS, and they differ from your OPINION so to try and save face you say that I was demeaning in my reply. Facts are facts, and if you find them demeaning it is entirely within your own head. Sweated copper airlines are perfectly safe and the fact that the very large, safety and liability obsessed company I work at uses them for hundreds of miles and miles of airlines - without failure or incident for the past 70-80+ years - is all the evidence anyone needs.
Now if you don't like or trust copper for air, that is fine, and iron pipe is also perfectly fine. But it does not change the fact that copper is indeed perfectly safe, just because you don't like it. And that applies to sweated joints as well as the pipe itself.
The immature, insulting reply is yours, trying to gaslight that my 100% fact reply is somehow insulting. But you are a well-known entity here on TBN, so I doubt this surprises anyone here.
/ PEX & Kinks #38
Been here a very long time and I'm sure I've ruffled more than a few feathers during that time.
Being north of 70 now, my tolerance for irrelevance is very limited and I only frequent this forum for entertainment mostly. Same applies to You Tube as well as Rumble and Twitter I might add.
1189 (A65054)
1189 (A65054)
2016 Peterbilt 348 26ft. Rollback Truck (A66736)
2016 Peterbilt 348...
x (A68191)
x (A68191)
John Deere 6420 (A64911)
John Deere 6420...
2021 CHEVROLET SILVERADO 3500HD SERVOCE TRUCK (A67714)
2021 CHEVROLET...
LINCOLN ARC WELDER (A67714)
LINCOLN ARC WELDER...
