PEX & Kinks
/ PEX & Kinks #1
Pettrix
High Desert Southwest
I am having PEX installed on a new house build. I noticed one of the lines had a kink/bend in it that was straightened out but you can still see where the PEX bent and caused a crease. Is this something to be concerned about? Should I have them install a new piece there?
/ PEX & Kinks #5
I would say the installer needs to fix that kink, since it looks like potential time bomb later down the road.
I had a crash course in pex pipe this week.
It's super handy, but as I found out, it can be a ticking time bomb.
I'm still fighting with the camper sales place over the leak we had due to an improper install.
/ PEX & Kinks #6
@Pettrix Don't even hesitate. Replace.
As @Chewwy's material points out, a kink ruins the strength and structural integrity of PEX. I would make sure that they replace several feet of the pipe to not be kinking the replacement section.
I hate to say it, but I would strongly recommend you going over ever inch of this installer's work, looking for small defects. It does not take much to generate an issue, and that photo says a lot to me about that particularly knowledge of PEX and their skill level.
Sorry.
All the best,
Peter
/ PEX & Kinks #8
Properly installed PEX is ok for RVs and mobile homes that don’t have a long life expectancy anyway. I would never use it in a permanent home. Copper is more expensive but will last much longer (70+ years) if installed properly.
/ PEX & Kinks #9
Does "installed properly" include something to combat acidity?
Why 10 Year Old Copper Pipes Start to Develop Pinhole Leaks.
When the potable water flowing through your plumbing system has a pH value that is less than 6.5, it can harm your copper water pipes. As the water moves through your copper pipes, it causes internal pitting of the pipe. Once those pits penetrate entirely through the copper, a pinhole leak develops.
/ PEX & Kinks #10
Installation quality would have nothing to do with water quality. It does reflect on owners and builders intelligence though. 😃😃
/ PEX & Kinks #11
Most new home builds use pex.
If installed correctly. It will last a long time.
My issue with the camper we just purchased (second hand) had some cobbled together plumbing that the RV sales place should have caught.
The former owner must have frozen it at some point. And did a half arsed repair. Used some cheap PVC push lock fittings for Pex. Cut the water line to the shower and clamped it to a smooth piece of PVC.
The fitting blew apart a few days after using the heat for the first time. And the sudden pop caused all those seals in the pushlock fittings to fail.
I ended up fixing it myself since the RV place wouldn't honor the 1yr warranty on the camper.
So I got a crash course in crimping pex in positions a contortionist would have a hard time reaching.
I invented quite a few new swear words as well.
We've only had the camper for 45 days. Hence my beef with the camper sales place
/ PEX & Kinks #12
I know this is a regional thing; but down here, it's 99% cpvc inside a building. When I was a plumbers helper, 20 Years ago, we did do roll copper under the slab and stick copper in walls/ceiling on commercial buildings.
/ PEX & Kinks #14
Depends on the neighborhood. Popularity is not a great indicator of quality, only of cost.
Look at the majority of new home construction.
It's your cookie cutter neighborhoods that are being thrown up as fast and cheap as possible.
I didn't say I agreed with it. Heck.... I don't agree with most building trends you see.
/ PEX & Kinks #15
I think it depends on water quality. Here PEX A is thought to have a 50 lifespan, far beyond copper. There are certainly different grades, and types of PEX. I'm not a personal fan of type B PEX. They are less likely to fail due to water hammer, or the odd earthquake. YMMV.
Of course, if you have, or expect to have rodents in your walls, that is different.
All the best,
Peter
/ PEX & Kinks #16
I built myself a new house in 1996 that is worth about $3.5 million today. I reluctantly used polyB because I was talked into it by my plumber as being superior to copper. Cost had nothing to do with it. That's the main reason I'm not sorry that I don't still own it.
/ PEX & Kinks #17
In theory maybe but hard water can and does eat away at the pipes which causes leaks much faster. It’s also common to have it incorrectly installed against steel which causes more leaks. And pex can withstand some amount of freezing where any freezing at all will bust the copper. When you do get leaks soldering wet copper is extremely difficult where fixing wet pex is easy. And pex last a long time. It doesn’t go around failing all the time like some people seem to believe.
/ PEX & Kinks #18
Construction is always a compromise between affordability and quality. You could build everything twice as good but housing is already unaffordable so that’s not really an option. Very few people want to spend 5x as much on plumbing that they’ll never see. And pex is actually a good product. It last a long time. I’d argue it lasts better than copper.
/ PEX & Kinks #19
pex-a I wouldn't worry. A heat gun will take the kink out and fix. pex-a be stronger and more forgiving.
pex-b on the other it will be permanently weakened so a simple fix would be done if me.
if your plumber still be around a simple fix and you be good to go. I would fix it. A buck or two and its fixed if plumber their.
/ PEX & Kinks #20
Post number 4 covers it nicely. However, my PEX has been in my concrete slab or over 20 years now with no issues but I installed it myself, always mindful of the minimum radius. That kink-crease will fail, have it replaced asap.
Kuhn GMD 4051 TL Trail Mower (A64047)
Kuhn GMD 4051 TL...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Bucket Truck (A60352)
2018 Freightliner...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
2023 John Deere 9RX 540 Track Tractor (A63109)
2023 John Deere...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2021 Chevrolet Equinox SUV (A61574)
2021 Chevrolet...
