Pallet Forks
/ Pallet Forks #11
I don't know how they could take longer than any other forks to put on, it takes about 30 seconds to install clamp-ons. I won't argue any of the other shortcommings, but there can't be a faster type to hook up. Plus they don't take up any space in the truck bed if you're trailering.
You maybe correct on the "clamp" on's-but the OP also mentioned chain-ons and they would certainly take longer than any QA setup.
/ Pallet Forks #12
i was going to get some clamp on forks, but when i saw my neighbors bent bucket from his clamp on forks...i desided to buy a quick attach style of forks.
they arnt too expensive and have a 4,000# rating. Mind you my loader only can lift about 2700# (3700 breaking lift).....so its probibly overkill, but i feel safer.
Also, the added safety of the frontt shield to protect my tractor and hood makes the $650.00 well spent cash.
/ Pallet Forks #13
I just used my QA forks a couple of days ago to install the mower deck under my Cub Lo-boy. I position the Cub behind the deck, then use the forks to lift the front of the Cub and ease it over the deck. I real like the visibility you have with the QA setup.
I originally got the forks for unloading and moving our whole house generator. As I'm sure you have read here, forks are one of those attachments you find lots of use for and will wonder how you got things done without them.
/ Pallet Forks #14
Get a set of real forks. You'll be amazed the uses you will find for them. I think my forks are on more than the bucket, between moving firewood, downed trees, popping stumps, popping larger objects such as those shown below. The ability to slide the forks anywhere you want lends itself well to using the forks as a digging implement also.
You are severely limited by having the load so far forward with clamp-ons, not to mention the potential bucket damage. The item below, I couldn't even get it off the ground if it was more than a foot from the backrack. With it all the way back, I could lift it 3".
/ Pallet Forks #15
I agree with most here, my Horst quick attach forks have already paid for themselves in saved time. I put my attachments on skids and move them around, I want to palletized my wood at some point to minimize handling, I did some tree removal the other day and used them to pile brush for my chipper then move the logs to my splitting pile. They are used all the time it seems. They snap on and snap off in the time it takes me to get off and on the tractor to through the lock pins arms.:thumbsup:
/ Pallet Forks #16
I too would recommend a dedicated sytem vs. bolt-ons.
I have a ATI Quick-Tach that works well. Down side is that you need to have your bucket welded with a reciever plate. But switching to forks or grapple is easy.
/ Pallet Forks #17
I heard Bradco makes a set for compact tractors too, lightweight etc, anyone know what the bradco website address is?
/ Pallet Forks #18
I'm looking to purchase a set of pallet forks for my JD FEL. Mostly I want to use them for unloading large purchases from delivery trucks: Box blade, cultivator, large furniture, etc. This will save me a ton of money in shipping charges so I don't need to pay for lift gate service.
Since my use will be limited I'm looking for some that clamp or chain on the bucket. Any thoughts on pallet forks that clamp on the bucket versus those that attach using a chain?
Thanks
Loader Forks Bucket Forks Skid Tractor Pallet Fork | eBay
I agree the high end stuff is nice to have.
For my $135 this set of forks works for me. They can be installed and removed very quickly and really need no storage.
As you can see in the last photo (power line poles) the cutting edge does not carry the load as the clamp on type. I tried to see if our 60 HP back hoe would break them but the loader bucket would by-pass when overloaded and they did not bend or break.
They are round which at first I was upset about because I did not catch that when I ordered them but it turns out in the hollow line of forks the oil well pipe is stronger of the options.
Keep in mind they are only $135 forks and the bucket blocks the view but I found putting a 2x4 in the standard loop helped know their angle. I have a spotter in most cases anyway.
/ Pallet Forks #20
always a funny guy, did you not think I tried that first. so let me rephrase, who makes bradco?? is paladin the master importer or??
FENCE PANELS (A58214)
CFG QK20R (A60463)
CFG QK20R (A60463)
AEREATOR (A58214)
AEREATOR (A58214)
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
John Deere Wheel Loader Forks (A60462)
John Deere Wheel...
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
