Optimum Welding Table Height?
/ Optimum Welding Table Height? #11
Scissor lift table is the best height.
/ Optimum Welding Table Height? #13
1.For fine work – working height: 39″ (100 cm)
For fine work, such as drawing, you should have your elbows supported. This relieves the core muscles. Recommended workbench working height is approx. 2″ – 4″ (5 cm – 10 cm) above elbow height.
2.Easy work – working height: 36 ” (90cm)
For light manual activities, such as assembling or processing workpieces, a working height of around 4″ – 6″ (10 cm – 15 cm) below the elbow is recommended.
3.Heavy work – working height: 31″ (80cm)
For labor-intensive work such as heavy assembly work, sawing wood or planing, low working heights are more favorable. A working height of around 6″ – 15″ (15 cm – 40 cm) below the elbow is recommended.
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
1969 Lincoln Continental Mark III Sedan (A59231)
1969 Lincoln...
2021 Ford F-250 4x4 Crew Cab Pickup Truck (A59230)
2021 Ford F-250...
2017 Kawasaki Mule 4010 4x4 Rescue Gas Utility Cart (A59228)
2017 Kawasaki Mule...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2001 John Deere M665 60in Zero Turn Commercial Mower (A59228)
2001 John Deere...
