Operating Tips
/ Operating Tips #21
BobRip said:
Adding weight to the back of the PT will not only reduce wheel spin, but allows the wheel torque to be used from all four motors giving you greater "push" for the machine.
Anybody have a pic or description to do this on a 425????
/ Operating Tips #22
A better solution might be to just add wheel weights to the rear wheels. This would put less stress on the articulated joint when you are carrying a full bucket of dirt, stone, etc., as opposed to hanging weight off the back end of the powertrac. You would still get as much if not more traction with wheel weights IMHO.
/ Operating Tips
You can also put fluid in the tires, non-freezing kind if needed for your climate.
/ Operating Tips #24
You could fill the tires for added weight and traction but I like the idea of wheel weights better. ( easy on & easy off as needed )
/ Operating Tips #25
Hate to ask dumb quetions....
but where does one find wheel weights? How do they attach?
I purchased/brought home a pallets of mixed slate (1'x1' 6"x6" 2"x2" etc.)
14 boxes of slate 1'x1' was the limit for the 425.
The sales guy said they weighed 50 lbs each x14 = 700 lbs.
Any turn over a few degress started bringing the pucker on.
However, It shure beat moving them a few at a time with a wheel barrow.
We leveled a pallet on the 425 with the truck/trailer. Slid the boxes over then used shrink wrap before taking them up to the new house over the rough terrain.
Love the PT...and want the weights when moving heavy loads!
/ Operating Tips #26
On the rims on my 425 there are 4 square holes you can use them to bolt the wheel weights on. I have a craftsman garden tractor that has wheel weights that are 55 pounds each and they can be mounted on the 425. By using this kind of weights , the weight is bearing down on the rim and not on the motor which in that respect is easier on the wheel motors but it would take a little more to get the wheels to turning. Considering the fulcrum point I believe it would give you more lift than the 110 pounds of wheel weights. You can probably find a used set if you search around. If you was to leave the weights on all the time you might get used to pushing the lift capacity of your machine and do damage, so that might be something that you might want to keep in mind and make two trips instead of overloading the machine to make it in one trip on the occasions where you can divide the load. Hope my ramblings help you. If you want to buy them new you can get them at sears
/ Operating Tips #28
Ah, the voices of reason.....
Yep, It may take me an extra trip or two lightening the load a bit...but seems the prudent thing to do. :eek:
I thik I'll go weightless.
/ Operating Tips #29
There are times that you can't divide a load and the wheel weights are nice to have. When I got my coal furnace for my garrage when I put the forks under it the pt would lift it ,but the pt was light and would pucker and with something like that I didn't want to drop it wheel weights in that case is good to have.
/ Operating Tips #30
Actually the maximum lifting ability of the PT425 is only slightly more than the pucker point!
Concerning traction, in dry conditions the wheels will usually just stop rather than spin.
PS: Try reversing the wheels for greater safety and stability!
In a PT425, use 11# of air in the front tires and 7# in the rear for the best traction, nicest ride, and least wheel motor wear!
/ Operating Tips #31
How did you work out the pressures to determine least motor wear?
FOURTEEN said:
... Try reversing the wheels for greater safety and stability!
/ Operating Tips #32
I want low impact on the motor bearings, enough carrying capacity, and a nice ride, so, on a concrete floor:
For the FRONT tires, I loaded the bucket to achieve pucker, then adjusted the tire pressure to about one half of the unloaded height. 11# has worked well. Enough air to prevent tire, or wheel, damage, but soft enough for a full footprint, to absorb shocks, and to provide a gentle ride when loaded or unloaded. When loaded the tires will 'caterpillar' up over obstuctions like rocks or logs. (A 'D' shaped tire rather than an 'O'.)
For the REAR tires, with the bucket empty, I adjusted the tires to be soft but with a flat, even footprint all the way across the tire without any cuping or bowing. 7# has worked well.
/ Operating Tips
Use your Power Trac to lift and hold large boards in place while nailing. I just used this on a 2 X 10 X 10ft board. No way could I hold this while nailing.
/ Operating Tips #34
Just today....
Put a pallet on the pallet forks....leveled with the truck and off loaded new washer and dyer. PUt them in storage in my barn until the house is ready.
Placed the washer in the corner...then leveled the dryer pallet with the top of the washer and stacked them. (They're designed to do this). Great back saver!
Will use the PT to move all appliances fromt the barn to the house when complete. About 400 ft away.
Hint: Strap the the load to the pallet to prevent it from toppling off when moving, lifting, etc.
/ Operating Tips #35
The size of the load will have the most effect on the wheel bearings, whether it is a rolling load or a bouncing load The side load will be the same no matter what the tire pressure, except when the load is bouncing. Lower air pressure will give a softer ride, but may also contribute to tire roll off. The advertised tire pressure for a certain tire is the pressure for the maximum load. You will notice that as the plies are increased, the max load increases. The price also goes up. The tire pressures that Fourteen published is for a PT-425
/ Operating Tips #36
Great points JJ.
I had enquired about the process so that it might be applied by others to determine tire pressures optimal for their purposes.
Unlike some folks, I do pretty much everything at slow speed, and usually on a slope. I'm happy with my current tire pressures, but I am always curious to learn more.
All the best,
Peter
/ Operating Tips #37
""Lower air pressure will give a softer ride, but may also contribute to tire roll off.""
That is why I said: " 11# has worked well. Enough air to prevent tire, or wheel, damage, but soft enough for a full footprint, to absorb shocks, and to provide a gentle ride when loaded or unloaded. ". Less than 11# can cause tire damage including that described by JJ. 11# seems to be the best compromise to prevent damage from both overly soft and overly hard tires on the Front of the PT-425.
'''The advertised tire pressure for a certain tire is the pressure for the maximum load.'''
True, but you seldom use maximum tire pressures. The advertised tire pressure is the maximum load allowed on the tire, not the maximum load allowed on the vehicle. With the OEM tires on my wife's Azera, Azera calls for 30#, far below the maximum tire pressure of 51# listed for that tire. At 51# each tire could carry a load of 1653#, but that would be excessive for a 3600# car, and would cause the car to ride and handle terribly, while possibly leading to suspension damage. On that car 30# provides the best ride and handling while protecting both the tire and the suspension. When I first bought my PT, I asked PT what the best tire pressures would be, but they didn't have a clue! So, as usual with my PT, it was 'do it yourself' time!
""The tire pressures that Fourteen published is for a PT-425.""
True, but the same proceedure could be used to find the best pressures for any model PT.
PS: Note the tire profiles in this full load picture. (Also my handy 'saw holder'!!)
/ Operating Tips #40
[ True, but you seldom use maximum tire pressures. ]
I disagree with that statement. I would venture to say, that about 95 % or all tires are run at the rated pressure. It only makes sense in the fact that tires are selected for load caring ability.
Yes. I agree that some vehicles use less air pressure in order to give a stable ride.especially when there is a large offset between the weight distribution on certain vehicles. If tires on these vehicles use max tire pressure, there will be less of a footprint, with the tendency to drift. The same is true about pickup trucks. If you use maximum pressure, you will have a stiff ride, and you will wear out the center of those . Some people reduce the tire pressure for a softer ride and a better footprint.
A bouncing tire will have a greater load on the bearings than the static load
Try this. Lay a 5 lb brick on your hand, no problem. Now, pick that brick up and drop it on your hand from 1 ft. Dynamic forces are involved here, and it will hurt like ****.
