Now able to move tractor from backhoe position. Push Button, 3D Parts, Should have come from the factory this way.
   / Now able to move tractor from backhoe position. Push Button, 3D Parts, Should have come from the factory this way. #21
adding limit switches would be a pain, that said it prolly wouldn't work for me. it would only work on level ground. i find i need to hold my tractor in place on hills, before the stabs go down, i find my pedal is all over the place, depending on the slop
That's interesting! Sounds like you're using the hydrostat as a brake until you get the stabs down. I do like the simplicity of your mod in spite of the thoughts about making it more complicated. :)
Edit: These electric over mechanical mods are interesting to me having a background in industrial controls. A hydrostat controlled throttle would be another one.
yep, couple seconds in relief, isn't going to hurt anything. and like I mentioned above. Its 1 pin partially remove it, and 2 clips to fully remove it. and the electric is also quick disconnect. it really is nice. I am real happy how it turned out.
   / Now able to move tractor from backhoe position. Push Button, 3D Parts, Should have come from the factory this way. #23
I agree, and truth be known, I'll bet that most hydrostats are passing a small amount of fluid over relief even when parked in gear and the engine running. I doubt that the pedal is always precisely "centered" when taking the foot off of it.
2016 FORD F-350 XL SUPER DUTY EXT CAB TRUCK (A59823)
2016 FORD F-350 XL...
2020 CATERPILLAR 299D3 XE SKID STEER (A60429)
2020 CATERPILLAR...
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2018 Kubota...
2003 McCormick XTX 185 XtraSpeed Tractor (A56438)
2003 McCormick XTX...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
Booster Cables (A59230)
Booster Cables...
