Now able to move tractor from backhoe position. Push Button, 3D Parts, Should have come from the factory this way.
   / Now able to move tractor from backhoe position. Push Button, 3D Parts, Should have come from the factory this way. #21
adding limit switches would be a pain, that said it prolly wouldn't work for me. it would only work on level ground. i find i need to hold my tractor in place on hills, before the stabs go down, i find my pedal is all over the place, depending on the slop
That's interesting! Sounds like you're using the hydrostat as a brake until you get the stabs down. I do like the simplicity of your mod in spite of the thoughts about making it more complicated. :)
Edit: These electric over mechanical mods are interesting to me having a background in industrial controls. A hydrostat controlled throttle would be another one.
yep, couple seconds in relief, isn't going to hurt anything. and like I mentioned above. Its 1 pin partially remove it, and 2 clips to fully remove it. and the electric is also quick disconnect. it really is nice. I am real happy how it turned out.
   / Now able to move tractor from backhoe position. Push Button, 3D Parts, Should have come from the factory this way. #23
I agree, and truth be known, I'll bet that most hydrostats are passing a small amount of fluid over relief even when parked in gear and the engine running. I doubt that the pedal is always precisely "centered" when taking the foot off of it.
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
New Holland WorkMaster 37 (A53317)
New Holland...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
