Now able to move tractor from backhoe position. Push Button, 3D Parts, Should have come from the factory this way.
   / Now able to move tractor from backhoe position. Push Button, 3D Parts, Should have come from the factory this way. #21
adding limit switches would be a pain, that said it prolly wouldn't work for me. it would only work on level ground. i find i need to hold my tractor in place on hills, before the stabs go down, i find my pedal is all over the place, depending on the slop
That's interesting! Sounds like you're using the hydrostat as a brake until you get the stabs down. I do like the simplicity of your mod in spite of the thoughts about making it more complicated. :)
Edit: These electric over mechanical mods are interesting to me having a background in industrial controls. A hydrostat controlled throttle would be another one.
yep, couple seconds in relief, isn't going to hurt anything. and like I mentioned above. Its 1 pin partially remove it, and 2 clips to fully remove it. and the electric is also quick disconnect. it really is nice. I am real happy how it turned out.
   / Now able to move tractor from backhoe position. Push Button, 3D Parts, Should have come from the factory this way. #23
I agree, and truth be known, I'll bet that most hydrostats are passing a small amount of fluid over relief even when parked in gear and the engine running. I doubt that the pedal is always precisely "centered" when taking the foot off of it.
1408 (A57192)
1408 (A57192)
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56435)
1992 Talbert 70...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2014 UTILITY VS2RA 53FT REEFER TRAILER (A57880)
2014 UTILITY VS2RA...
