No fuel
/ No fuel #1
DLey
White 6105
I have a white 6105 and am getting no fuel. put in new crank sensor and new fuel governor .was not getting amp draw while cranking and has code 2 have power and ground to controller any advice is appreciated
/ No fuel #2
Does it need the filters replaced? If you take a fuel line off does fuel gravity flow out of the tank? Does it have a lift pump and if it does is it working? Does it have a fuel shutoff solenoid and is it working? Plugged out let from fuel tank? Plugged or collapsed fuel line? So many possibilities we need more info.
/ No fuel
If you take off the fuel governor you can manually move the rail and it will run.the test to check a code 2 is to check amp draw to governor should be 2amps while cranking.I am getting no amps so replaced governor still code 2 for circuit shorted or open.I have power and ground to module and voltage coming out of module.
INDUSTRIAL GOLD 133 GALLON COMPRESSOR (A67714)
INDUSTRIAL GOLD...
Set of 4 Unused 10-16.5N.H.S. ForeRunner Skid Steer Tires (A66734)
Set of 4 Unused...
OUTBOARD ENGINE STANDS (A66738)
OUTBOARD ENGINE...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
CAT 988B Final Drive (A68134)
CAT 988B Final...
2024 Ford Explorer SUV (A61574)
2024 Ford Explorer...
