No fuel
/ No fuel #1
DLey
White 6105
I have a white 6105 and am getting no fuel. put in new crank sensor and new fuel governor .was not getting amp draw while cranking and has code 2 have power and ground to controller any advice is appreciated
/ No fuel #2
Does it need the filters replaced? If you take a fuel line off does fuel gravity flow out of the tank? Does it have a lift pump and if it does is it working? Does it have a fuel shutoff solenoid and is it working? Plugged out let from fuel tank? Plugged or collapsed fuel line? So many possibilities we need more info.
/ No fuel
If you take off the fuel governor you can manually move the rail and it will run.the test to check a code 2 is to check amp draw to governor should be 2amps while cranking.I am getting no amps so replaced governor still code 2 for circuit shorted or open.I have power and ground to module and voltage coming out of module.
2020 ISUZU NPR 16FT BOX TRUCK (A59914)
2020 ISUZU NPR...
CAT 345CL NEW Track Chains (A68134)
CAT 345CL NEW...
2007 PETERBILT 335 SERVICE/LUBE TRUCK (INOPERABLE (A67714)
2007 PETERBILT 335...
2010 Honda Civic Sedan (A66738)
2010 Honda Civic...
2018 Land Rover 4WD SUV (A61574)
2018 Land Rover...
2017 CATERPILLAR 308E2 CR EXCAVATOR (A65056)
2017 CATERPILLAR...
