TractorTech
Elite Member
- Joined
- Jan 26, 2012
- Messages
- 3,125
- Location
- California
- Tractor
- Ford 7710, Ford 550, Ford 1910, Ford 4430, KD Forklift, Ford LGT17H, New Holland L255 Skidsteer
1700 has gravity feed to injection pump only. Open the bleed screw at the filter until air is gone, then the injection pump bleed until air is gone, then the injectors. But, you need fuel to the filter first!The fuel pump has a manual pumping lever, do not use the starter to bleed the system. Open the bleed screw and work the lever up and down until all the air is out.
